Old 07-29-2023, 09:24 PM   #1
triggerjerk
Drives: 2023 Camaro ZL1
2023 ZL1 with a tick
Hi all,
I picked up a 2023 ZL1 two weeks ago (long story hunting/ordering).
Well, it has a loud tick/tapping noise coming from the rear of the engine compartment (and other problems worth their own threads). I don't think it is engine related. I was wondering what everyone thought. I know this issue has come up before. I also know that DI motors are noisey but this is on a whole other level and is louder than my friend's ZL1s ('21 and '22).
See vid below. Note: it doesn't happen on cold starts. It comes when the engine has been running a few minutes and then comes and goes. Sometimes at idle it comes but when I accelrate from a stop it goes away. Weird.
https://www.youtube.com/shorts/_VcGBQaNsPE
I have an appointment with the dealer next friday. If I get the "couldn't duplicate customer concern" I am going to lose my mind.
triggerjerk is offline   Reply With Quote
Old 07-30-2023, 01:12 AM   #2
SammYyYyY
Drives: 2018 ZL1 1LE
Yeah, you don’t need me to tell you this, but that is FAR beyond normal DI noises, especially from the interior.
This is even on an entirely different level from my serpentine belt tensioner failing (which, by the way, everyone thought I spun a rod bearing when I posted it here, so yeah, that sounded BAD), which can be heard here: https://youtube.com/shorts/gdYdMrSlf9c?feature=share
If your dealer starts jerking you around, open a case with GM directly.
SammYyYyY is offline   Reply With Quote
Old 07-30-2023, 09:37 AM   #3
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Definitely a strange noise. My thoughts is it might be in the exhaust system somewhere. Maybe bolts have come loose and need to be tightened. My ZL1 doesn’t have a noise like that but some other noises on cold startup that go away when the engine gets to operating temperature. Good luck and get it to the dealer since it is an issue for warranty.
Old 07-30-2023, 01:02 PM   #4
h1nch
h1nch's Avatar
Drives: 2023 Camaro ZL1 6spd
Originally Posted by triggerjerk View Post
Hi all,
See vids below. Note: it doesn't happen on cold starts. It comes when the engine has been running a few minutes and then comes and goes. Sometimes at idle it comes but when I accelrate from a stop it goes away. Weird.
And from the interior. Volume isn't the greatest but it sounds like a tapping on the firewall and floorboard. Very obvious to passengers.
https://www.youtube.com/shorts/3zIcx2A8SFw
I have this EXACT same issue on my brand new ZL1 that I picked up 8 days ago. I brought it to the dealership for its first oil/diff fluid change and they told me that they believe the problem to be this TSB: https://static.nhtsa.gov/odi/tsbs/20...16662-9999.pdf
I have an appointment to bring the car back next week as my schedule would not allow me to leave the car with them this week.
Let me know what your local dealership finds, in case the problem ends up being something else.
h1nch is offline   Reply With Quote
Old 07-30-2023, 01:10 PM   #5
triggerjerk
THANK YOU. EDIT: Do you know your build date? Mine is 5/25/23.
I think others have had this performed and the sound came back.
Still seems weird that it sounds like an exhaust leak . . .
I will for sure update this thread after friday.
Old 07-30-2023, 02:35 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Came here to say fuel line.... was an issue several years ago. Some things come, some things go, and some things come back.
Old 07-30-2023, 02:57 PM   #7
LT4Greg
LT4Greg's Avatar
Seems like that might be the problem! Hope you get it fixed.
Old 07-30-2023, 05:26 PM   #8
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Wow thats really F up
Old 07-30-2023, 05:34 PM   #9
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Not normal!
Old 07-31-2023, 03:28 PM   #10
Supercharged!
my new ZL1 is in the shop today for this exact same issue
I should be getting a call back shortly so I’ll update this thread as I learn more. My car was built in June 2023
I’m actually glad to know its not just me, I hate having my car sound this bad.
Supercharged! is offline   Reply With Quote
Old 07-31-2023, 04:48 PM   #11
Supercharged!
Here is the recording from my car
https://youtube.com/shorts/nD3hjG714kU?feature=share
Old 07-31-2023, 04:48 PM   #12
h1nch
h1nch's Avatar
Not sure of my exact build date but the door sticker says manufacturing date of 06/2023
Glad to know this is likely a known issue and not a sign that my car is a lemon
Old 07-31-2023, 05:26 PM   #13
Supercharged!
ok, so it seems to be a June-ish 2023 build issue
Old 07-31-2023, 05:35 PM   #14
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
I was just going to say the same. My car is a 2023, but was built July of 2022. I have 566 miles on it and haven't had this ticking noise(knock on wood, YET). Very unfortunate for you guys with the June '23 build date. I hope it's only isolated to a few units and not a larger problem. Hopefully GM will look into it a bit further if there happens to be more cases of this. Sorry this has happened to those that are experiencing it, but hope you guys are able to get it fixed soon!
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
