Old 06-19-2025, 06:24 AM   #1
Chev133
Drives: Chevrolet Camaro zl1
Hyper flashing turn signals
Hi,
Has anyone ever had hyper flashing turn signals fixed by reprogramming the BCM? I’ve tried load resistors but nothing works. I’ve been told that you can reprogram the BCM but can’t find anything on you tube ect.
Thanks. Anthony.
Chev133 is offline   Reply With Quote
Old 06-19-2025, 06:36 AM   #2
clg82
Drives: 2020 Camaro ZL1
What did you do to make it change from normal flashing? That would help to know so we could help diagnose said issue.
Old 06-19-2025, 09:59 PM   #3
Chev133
I fitted the C8 auto addicts tail lights.
Old 06-19-2025, 10:03 PM   #4
Chev133
How did you find the atlas port injection? I’m about to pull the engine & doing a very similar build.
Old 06-20-2025, 08:01 AM   #5
clg82
Are you asking me? You don’t need to pull the engine for the DSX Atlas port injection….
Old 06-20-2025, 08:04 PM   #6
Chev133
I’m doing oil pump & cam.
Old 06-21-2025, 12:02 PM   #7
TheDocKlopek
Drives: 2018 Camaro ZL1
It may not be related but I had the same issue with both of my newer taillights I installed. I of course didn't read the manual and just hooked everything up, then realized that you hook up the lights differently if its LED or non-LED. Read that manual!
After correcting the wire hookups, both taillights work properly and have ever since.
2016 2SS Vert 6M Black/Adrenaline Red (Lost in Hurricane Harvey)
2018 ZL1 Vert 6M Garnet Red Tintcoat
TheDocKlopek is offline   Reply With Quote
Old 06-23-2025, 06:46 AM   #8
clg82
Oh i see lol I was confused, my installer ordered the DSX Atlas and dual widebands straight from DSX. I know they do take some time because a lot of the wiring is done in house and on a per order basis. Either way give DSX a call they'll help you with a timeline.
