Old 06-17-2025, 02:30 AM   #1
sosa69
Drives: Camaro Lt V6
Catalytic Converter
hi i need some help.Mostly from my peeps in Cali. i plan to do a secondary cat delete on my 6th gen maro but i need to know if my car will pass smog after
now i know it won’t trigger a check engine light since the ecu only monitors the primary cats but will it still not pass smog when i do my secondary cat delete?
sosa69 is offline   Reply With Quote
Old 06-17-2025, 07:07 AM   #2
It is true that the ECM doesn't monitor secondary cats, but you will only pass emissions if it's limited to OBD-II checking with no visual or camera inspection of the underbody.
Old 06-17-2025, 07:35 AM   #3
clg82
Drives: 2020 Camaro ZL1
You won't pass.....you will fail the visual...I just moved from there after 10 years......and you misspelled "Camaro"
Old 06-17-2025, 08:06 AM   #4
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
I thought they still did tailpipe test
bishopts is online now   Reply With Quote
Old 06-17-2025, 09:19 AM   #5
clg82
They do, their even more stringent these days. They start with the visual, and than move to the sniffer. I failed the last go around because I had a catch can.........glad i left that place.
Old 06-17-2025, 12:39 PM   #6
Rnovrit
Drives: 2018 NFG ZL1-1LE
You will fail the visual. On newer cars it is just a visual inspection, check the gas cap if you have one, and they plug into the ODBII port to check diagnostics. The sniffer/roller test I believe is usually for vehicles 1996 ish and older. Also, the secondary cats are part of the muffler exhaust system. The primary cats can be purchased separately but the secondary cats come as part of the entire 11' long exhaust system. So if you remove them and need to replace them, FYI it will cost you a chunk of cash. I had a primary cat fail and took out the secondary. Had to replace the entire exhaust system just to get the secondary cats.
Rnovrit is offline   Reply With Quote
Old 06-17-2025, 03:51 PM   #7
bishopts
bishopts's Avatar
Cant you just pull the rear cat and gut it out?
Old 06-18-2025, 07:58 AM   #8
clg82
Originally Posted by Rnovrit View Post
The sniffer/roller test I believe is usually for vehicles 1996 ish and older. .
This is incorrect, "New" cars off the lot, sold as "New" have a 4 year grace period, at year 5 they start the sniffer test. And believe me they will get you on year 5. The state doesn't miss year 5
Old 06-18-2025, 08:34 AM   #9
bishopts
bishopts's Avatar
Here in Texas we have a 2 year grace period for cars that require inspections. But this year we dropped safety inspections and only counties that are high population or attach to high population counties have to do emissions test. And it's just obd2 with 1 monitor can be not ready.
Old 06-18-2025, 09:06 AM   #10
clg82
I agree, I had my car done last weekend, took me longer to drive there then it did the inspection. I love this place.
Old 06-18-2025, 10:57 AM   #11
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
First smog check:
The first smog check will be due when you renew your registration in a few years, typically when the car is 6 years old, so on the 7th renewal you will need to smog or in some cases, when it's transferred to a new owner.
And any if you delete any of your CATs you will fail.
IMCWORTH is offline   Reply With Quote
Old 06-18-2025, 11:41 AM   #12
clg82
Originally Posted by IMCWORTH View Post
First smog check:
Damn it's year 7 now on new cars? Hmm that's good! Although if you get pulled over by CHP and they write you a ticket for said exhaust modifications etc than get state reffed, than have to put it all back on blah blah blah haha that could be bad.
Old 06-18-2025, 12:41 PM   #13
Rnovrit
Thank you but your information on CA emissions testing is not correct. I live in Ca and deal with this regularly with both my personal vehicles and company fleet vehicles. My 2006 Expedition has never seen a sniffer. Each year it is ODBII check only. The dyno/sniffer is usually saved for pre ODBII vehicles, vehicles labeled as gross polluters and any with special requirements. I can not verify for larger commercial vehicles over 10k lbs gvw. Depending on the age and type of vehicle, there are different types of emissions tests required.
Old 06-18-2025, 01:46 PM   #14
clg82
You're trolling us right?
california, camaro, catalytic converter, exhaust
