Old 06-14-2025, 06:16 PM   #1
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Ignite Red vs C98/X98 vs One Ethanol R/S
Gents
Looking to have a discussion with those making 1150-1200 WHP or more. My local pump E is pretty crappy lately, coming in around E60 out of the pump which is lower octane than I’d like this year. Do you guys have a preference of the above stated brands or are they all suitable for 20+ PSI on 10:1 compression? Ignite Red looks killer at 114 octane but probably overkill… and it’s $100 for a 5 gallon jug out my way… ouch lol. But if Ignite is really that good I’ll just do that.
Thanks in advance.
Old 06-15-2025, 10:44 AM   #2
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
From memory C98 has mek in it, which is great for making power but not great sitting in injectors for extended period of time. Maybe something to keep in mind if the car sits. We used to use mr9 and mr12 in bikes and always had to flush the fuel system after use so it didn’t tear stuff up in the fuel system. I’ve personally only messed with X85 and other brands like it of basic e85 in a pail.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 06-16-2025, 09:48 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would just order a drum of Sunoco E98 then blend it to your desired content %.
435.00 for a 54 gallon drum.
Old 06-16-2025, 12:38 PM   #4
calypso50kid
Drives: 2018 zle, 03 cobra, 92 mustang lx
Are you wanting to mix that in with the pump 60% you're getting to get up to 85%, or are you looking to run it solely alone? I've personally only ran c85 from VP in my turbo street car (4.6 4v with a 85mm been 4.92 at 145 made 1286 at the wheel through a th400) and it didn't pick up at all from pump e85. I know the one ethanol stuff is good from friends that run it, I have no experience with ignite however.
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm
https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8
2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles.
calypso50kid is offline   Reply With Quote
Old 06-16-2025, 01:23 PM   #5
KingLT1
KingLT1's Avatar
No he wants to get higher E content. Currently his pump only produces E60. If his local pump was actually producing E78-80 he probably would be content.
Old 06-16-2025, 04:35 PM   #6
Joshinator99
Moderator
Yep, this. I’d like to get the octane number up and don’t want to worry about what the local pump is putting out.
There was a horror story on the local E85 enthusiast board about some local station had a tanker drop a whole load of 87 octane into their E tank. So guys were filling up expecting E85 and it tested out around E30, so the natives are up in arms lol (understandably).
Old 06-17-2025, 11:33 PM   #7
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
One Ethanol R is some rowdy stuff. Use it a good amount in the LS platform where fueling isn't so limited. It took more timing than I ever imagined in a H/C C6 ZR1 never did detonate, it just stopped making power.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 06-18-2025, 08:24 AM   #8
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
I would get a 55 Gallon drum of Sunoco E85R or Ignite 98(if you want to mix down to E85). I think the higher best overall value is still E85R if you compare to the math with the higher E% fuels and mix down.
I doubt you will see any power gains past E80.
GM Gen V Calibrator
Old 06-24-2025, 02:02 PM   #9
Katech_Mike
Drives: 2015 Camaro ZL1
I would recommend One Ethanol E85-S. Similar stoich to pump E85 so you can switch to pump if needed without needing to revise the tune. 54g drum is $459.
Katech_Mike is offline   Reply With Quote
Old 06-24-2025, 10:52 PM   #10
Joshinator99
Moderator
Nice, thanks Mike.
Old 07-28-2025, 01:51 PM   #11
clg82
Drives: 2020 Camaro ZL1
Hey Josh, did you ever end up going with the E85-S. I am looking to get closer to 85 on my car as well since I can at the most only get e70, out of the local pump here. Not bad I know, but was thinking about mixing my own E85-S if that would get me to the full ethanol content. I did read this on their website: "engines that typically use race fuels with an octane rating of 100 to 112." Does that mean I can still use this "S" variant on my build? Maybe Mike at Katech could help chime in. Thanks for any help guys!
Old 07-28-2025, 07:17 PM   #12
Joshinator99
Moderator
I wasn’t able to come up with the One Ethanol S in time for the dyno. I had 5/8 of a tank of E60 and I wasn’t happy with that so I dumped in 5 gallons of Ignite Red just to get the E content up and provide a little safety against knock. I was E70-E72 during my runs which was fine. But yeah, my goal is to probably just run pump E on the street (E60+/- is fine since I’m half boost for street use)) and I’ll get a drum of One Ethanol S for track days.
You can definitely run the One Ethanol S in your car.
Old 07-29-2025, 07:47 AM   #13
clg82
Very cool, good t hear you got it at least in the 70 percentile for your dyno run!
Old 07-29-2025, 09:11 AM   #14
KingLT1
KingLT1's Avatar
You are not going to gain much of anything over E70 except a lighter wallet.
