Old 06-13-2025, 09:38 PM   #1
V6ontario
Drives: 2017 Chevrolet camaro
Staggered setup for 2017 v6 RS?
I am getting a good marketplace deal for 4 tires with staggered setup - my stock size is 245/40/20 - the staggered rear tires come with rims which were on a 2015 2ss - 275-40-r20
V6ontario is offline   Reply With Quote
Old 06-14-2025, 12:55 AM   #2
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Meh, I'd just save the money for 1LE sized wheels / tires. So worth the upgrade.
Need4Camaro is offline   Reply With Quote
Old 06-14-2025, 05:54 PM   #3
#facts
Old 06-14-2025, 08:14 PM   #4
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
I recently upgraded to 1LE wheels on my SS. It was well worth it. It looks awesome and I now rarely see the traction control light. Grip for days in corners. Well worth it. I've concluded that the car should have come this way from the factory...and it could have but mine is a daily and a 1LE car at the time seemed like overkill.
-Ray
Ray3768 is offline   Reply With Quote
Old 06-14-2025, 08:35 PM   #5
buckwam
Drives: 2021 camaro 1ls
I would go with SS size wheels on a V6 if they are a good deal. I have them on my turbo 4 and the 1LE wheels are heavier and tires more expensive and not necessary at our power level.
buckwam is online now   Reply With Quote
Old 06-15-2025, 08:05 AM   #6
Mid_Life_Crisis
Mid_Life_Crisis's Avatar
Drives: 2023 Chevy Camaro 2LT V6 6MT
I would consider buying some OEM SS rear wheels on eBay that will fit 275 or 285 width. Perfect for the V6 power and will fill in that rear wheel better than the skinny 245.
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
Mid_Life_Crisis is offline   Reply With Quote
Old 06-15-2025, 01:06 PM   #7
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
Check your offset on the fronts putting Gen 5 rims on gen 6, make sure you're not hitting the strut. But yes you can put SS rims on the RS with the LGX, I had no issues when I did.
dpevans is offline   Reply With Quote
Old 06-15-2025, 01:08 PM   #8
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
1LE wheels are slightly lighter (a pound or two iirc) than SS wheels especially since they’re forged instead of cast. The tires being more expensive is true
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-15-2025, 10:45 PM   #9
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Am I reading the OP correctly: the rear tires he's planning to get are 275/40/20? If so, that's likely to be a problem because they are 28.7" in diameter. That's way taller than any tire that's ever come OE on any 6th-gen Camaro, and it may cause issues with interference. It will also handle and stop worse. It may also cause a problem with the ABS and Stabilitrak if it's way taller than the fronts. What size are the fronts in this set of tires?
For reference, all 6th-gen Camaro SSs have come with 275/35/20 rear tires, which are 27.6" tall, and those along with the 245/40/20 tires that came on the OP's car (and on the front of 6th-gen SSs) are the tallest tires installed on any 6th-gen.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 06-15-2025, 11:16 PM   #10
Bumbleboy92
Long hauler
I didn’t notice that, looks like OP is getting these off a 2015 SS so 5th gen specs. I ran 5th gen SS wheels on my 6th gen LT and it worked but swapped to 6th gen SS wheels due to some abnormal ride feel back then, my car came with 18’s originally
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-16-2025, 07:04 AM   #11
Msquared
Msquared's Avatar
To be clear, 5th-gen wheels will probably work fine on a 6th-gen. 5-th-gen tire sizes probably will not.
Matt Miller
2020 SS 1LE
