Old 06-09-2025, 04:08 AM   #1
YG8
Drives: Camaro SS
Thinking of Procharger for daily driving and emissions legal
Hello all,
I purchased a ‘22 1SS as a daily driver, ~7-8k miles a year. I want to put a procharger, and keep it reliable. It will see drag strip no more than 3-4x a year, at most. I don’t plan on taking it to the strip often; however, I would like something to have fun on the streets, hear the whine, etc.
I gathered from research that for a reliable, daily street driven SS, a P1x, 6-7 lbs boost, I will hopefully get 550 horses on 91 octane and be safe while being emissions legal.
Another question is about getting a flex fuel kit for E85. I know I can run Both 91 and E85. Will I pass with the CA emissions tuned for the flex fuel kit? Obviously, I will have 91 during emission testing.
Thanks all and sorry for the noob questions.
YG8 is offline   Reply With Quote
Old 06-09-2025, 08:08 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by YG8 View Post
Hello all,
You won’t pass CA emissions the instant you change the tune to anything outside of the canned Procharger tune unfortunately. You would need to upgrade the fuel system to run any E with boost as the LT1 fuel system will be maxed out even on pump gas with a supercharger.
Old 06-09-2025, 10:04 AM   #3
GreyGhost702
Drives: 2019 Camaro 1SS1LE
If he got a custom tune from say Jannetty and then swapped back to the procharger tune for emissions time, would he fly under the radar? I'm not familiar with CA testing parameters. Why would the caned ATI tune pass and a custom tune fail?
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 06-09-2025, 10:58 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
CA emissions testing involves comparing the car's calibration to what they show in the OEM database. If there's a calibration in the car that doesn't match what's in the database, the car will "fail". I've, also, heard that even if you have a CARB calibration, passing could be difficult because CARB and CEPA don't share information (of course - it's CA...), so even though CEPA might have the calibration, if it isn't in CARB's database, that's a complication. yay... There's a chance he could have an E' tune, and reflash to the CARB-Procharger tune at smog time, but there was talk about a flash counter being in the equation some time ago. I don't know whatever happened with that. I heard that it might not be a big deal, but it's something to be cognizant of.
'20 ZL1 Black "Fury"
Old 06-09-2025, 11:01 AM   #5
beowulf556
Drives: Camaro SS 1LE M6
Can you just pop off the belt, flash the stock tune and then pass smog? Then change everything back?
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 06-09-2025, 11:54 AM   #6
Owl3
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1
Isn't there also a visual check in CA? They'd see the supercharger....
Finally on the way to 1K.....
Owl3 is offline   Reply With Quote
Old 06-09-2025, 12:15 PM   #7
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
There is he would have to use the kit that's 50 state legal which utilizes the factory air box. The catch with that is the kit is only legal in Cali with the p1sc1. He'll still reach his goal with that if the tune is right.
d1sc factory box w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 06-09-2025, 03:29 PM   #8
YG8
Drives: Camaro SS
Originally Posted by WiggyB View Post
There is he would have to use the kit that's 50 state legal which utilizes the factory air box. The catch with that is the kit is only legal in Cali with the p1sc1. He'll still reach his goal with that is the tune is right.
With just the procharger (p1sc1) and nothing else, do you think I will be hitting my ~550 whp goal on 91 pump gas with the procharger tune.
Thanks
Old 06-09-2025, 03:38 PM   #9
Joshinator99
Moderator
Thanks
You probably will on a cooler day on your first pull. With only 91 octane you’ll likely see some timing pull and less power on subsequent pulls, or very hot days.
Old 06-09-2025, 04:19 PM   #10
WiggyB
WiggyB's Avatar
Thanks
When I first installed mines it made 565whp but that was on 93. Not sure what it will make on 91 but I'm sure it wouldn't be too far off from that.
Old 06-09-2025, 04:32 PM   #11
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
Would it be possible to just pop in a spare ECM with the PC tune and then swap back to the other one all year?
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 06-10-2025, 07:55 AM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That is a route I'm taking, if necessary. I've probably burned 300-tunes to my car, so it'll be interesting (next September) to see what happens. If nothing else, I have a brand new ECM I can use, and resort back to this one when I'm ready.
Old 06-10-2025, 10:23 AM   #13
GreyGhost702
Could always pour to bump octane. It'll be a little harder on the cats, but FI cars are anyways. But lets be honest, how many opportunities do most of us have of hitting our max power on the street anyway? Once or twice in a drive safely? If he's at a track day, he can find a race gas pump somewhere and mix a little to octane up for some knock resistance.
Unfortunately there isn't much to be done about IAT's other than building a great heat exchange setup. Getting the hot air off the intake will be paramount right next to cooling the air charge as much as possible. Build the car to shed heat and go with a custom air to water intercooler, about the only way to get consistency without relying on ethanol to do the dirty work.
As far as getting around CA emissions, I still think tune swapping is the best bet. Procharger has been selling 50 state emissions legal kits for the 6 gens for a while now, I can't see how it wouldn't be recognized. As far as flash counts, burn that bridge when you get there. As was stated, if the flash count burns you, then you won't have a choice but to run a second ECM. What's scary about CA is they have the Smog Gestapo running around with mobile emissions testing units. You could get profiled by a clown car, pulled over, get the 4th amendment beat out of you, and then emissions tested right there on the side of the road while the tow truck waits for his signal. Not sure if they'd tow ya immediately but I can't imagine driving away without a fat fine of some kind.
Old 06-10-2025, 11:16 AM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I agree a bit, but how many people buy these, and how many have been smogged? CA cars don't have to be smogged until they're 8-years old, so there isn't a huge amount of these getting into the system.
