![]() Drives: 2017 Camaro 2SS Fifty Join Date: Apr 2021
LT1 aftermarket boost and AFR gauges?
Hi folks, I have a stock 2SS Fifty, and in a couple of days I am picking up a new to me SS 1LE with a Maggie as well as a few other mods.
I don’t think he added gauges, so I would like to add a couple. I see a lot of you use Banks, is that my best bet, and what, if any, extra sensors do I need to add? Any thoughts are appreciated, thanks! |
I love the Banks gauges. Very customizable. I installed mine in the pillar pod from ZZPerformance.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
Banks is great if you want to monitor multiple PIDS. If you just want Boost/Vac and Wideband, I recommend AEM for a Wideband. Get the one that allows you to passthrough Wideband datalogging. Your choice for a Boost/Vac.
Once you go down the Banks path, it's tough to live without seeing everything. Borderline obsessive. As far as monitoring wideband through Banks only, I don't know anything about that.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
![]() Drives: 2018 Camaro 2SS, 1LE Join Date: May 2025
I’m also looking to add boost & AFR/wideband gauges very soon.
I’m going with the AEM for the wideband but a little unsure which one I need. Does anyone know specifically which AEM gauge you need for the ability to get remote tunes using HPtuners. I’m thinking it’s the one that plugs into your OBDII and allows pass through data logging like GreyGhost702 previously mentioned? Edit: After looking online more, I answered my own question. HPtuners even sells the gauge setup on their website. (Link to it) it’s even cheaper on their site, than Amazon currently.
2018 Camaro 2SS 1LE
Current Mods: 2.9 Whipple SC, McLeod stage 2 Clutch, ARH 1" 7/8 Long Tube Headers, RotoFab CIA. Last edited by 509Driver; 06-03-2025 at 04:10 AM. Reason: Updated info |
#5 | |
Moderator
#6 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I keep both the iDash and ZZP in stock. The one button data logging is awesome also.
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#7 |
Banks also has other sensors that can integrate into the iDash gauges.
#8 |
Thanks guys, much appreciated!
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Don't have a boost gauge cuz NA.
But here's my AFR Wideband, and no my gauge doesn't allow me to switch to true lamda values far as I know. And don't ask me why my phone won't see the digital display, but it is clearly visible without the phone camera.
