Old 05-25-2025, 08:24 AM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Arrow Fuel Filter + Bracket Kit ?
Hey guys, still stuck with the car on jack stands with no less than (10) separate projects happening on the car. If you follow my thread HERE... you know I am upgrading my fuel system with the Katech dual drop in pump, and the XDI +50%. Anyway, with the need of installing an inline filter, and wanting to clean up the engine bay a little more, I decided to just replace all of the fuel lines with some Raceflux -8 braided. In that process I designed a simple bracket to secure the inline filter under the car, and made a few extra (1) for a friend, and a few more just in case I decided to offer the bracket + filter + clamps as an assembly down that road. That said, what do you think? Do you see any value in offering this as a remote filter package? Retail would only be around $175 for the bracket + -10 ORB filter housing + 10 micron magnetic filer + clamps + hardware...
I still might offer to replicate my entire fuel line kit as a DIY ready package, but for now, just considering the filter + bracket kit...
Thoughts?
Old 05-25-2025, 12:21 PM   #2
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
That setup looks awesome Gabe! I’m sure there’s definitely demand for a filter kit, or a complete kit with hoses and everything. Would make things a lot simpler for many people.
I would’ve ordered one right away if I wasn’t nearly done with my own setup. Just waiting on a replacement fitting now, figures it started leaking right when I thought I had everything wrapped up!
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 05-26-2025, 02:13 PM   #3
1wraith76
Drives: None
Thoughts?
Let me know how the XDI inj3ctors work for you. 929 to the wheels with a maggie 2650, 416 stoker kit, Katech heads, etc. DI with the XDI didnt work out well. Port injection just installed and waiting for a tune. This is why I have not been able to give you feedback on the bumper and rain guard kits yet. No track time.
My XDI were causing issues above 50% - 70% throttle. Let me know how it goes.
Love your products BTW.
1wraith76 is offline   Reply With Quote
Old 05-26-2025, 02:17 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
How much E were you trying to run? I’m at 1059 WHP on DI only but had to keep it at E50. I just added port as well so that I can get over 1100 WHP on full E… just need some dyno time.
Joshinator99 is online now   Reply With Quote
Old 05-26-2025, 03:10 PM   #5
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Very Nice !
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 05-27-2025, 06:47 PM   #6
ZapperZ
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD
ZapperZ is offline   Reply With Quote
Old 05-27-2025, 08:47 PM   #7
2023_ZL1-AUTO
Drives: 2023 ZL1
Way to go bro ! I can't get those WHP numbers as I'm still stock CAM, stock DI and stock heads! But, you all still inspire me to want more WHP! Even with an X-ported blower, and once I added the Katech Dual fuel pump and THPSI Port Injection. I'm able to run full E85 with all the fueling I can use @ +20psi ! Keep up it up !!!
Old 05-28-2025, 09:42 AM   #8
clg82
Drives: 2020 Camaro ZL1
When you say "the need for an inline fuel filter" is this a requirement of the Katech dual pump installation, or something you wanted to do on your own?
Old 05-29-2025, 12:27 PM   #9
SOCAL.M6.ZLE
That is a Katech suggestion... Speaking to DEATSCHWERKS at SEMA, they also recommend a 5-10 micron filter.
I believe the OEM filter is in the 70-100 micron range, which can cause an issue with Di injectors.
Old 05-29-2025, 12:29 PM   #10
SOCAL.M6.ZLE
Hey buddy, thank you for the kind words! Sorry to hear about your injector issues. I was told by multiple tuners to use XDI for their consistency. Although no ones consistency is 100%, but they had the best results with them... fingers crossed.
Old 05-29-2025, 12:41 PM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I believe because Katech adds a second filter in the module (bucket), it eliminates the OEM filter that occupies the same space. Because there is no more filter, one needs to be added.
The DSX bucket might do the same thing, because it's architecture isn't that much different than the Katech (billet, opposed to the OEM material), so I'd imagine it would require the addition of a filter, too. I can't remember if their website says anything about it.
'20 ZL1 Black "Fury"
Old 05-29-2025, 02:33 PM   #12
2023_ZL1-AUTO
Drives: 2023 ZL1
Correct, Katech added a filter to mine when they did my fuel system including the Drop-in Dual Fuel Pump. Mine is located on the fire wall, at top/back of blower, their filter also includes (and conceals) my FlexFuel sensor!!!! So looking at my engine bay, my FlexFuel sensor is not visible !
Old 05-29-2025, 02:46 PM   #13
swisstyphoon
Dave from DSX told me to run an auxiliary inline filter because the stock filter in the bucket gets eliminated to make room for the second pump. So yes, similar to the Katech setup, the DSX dual in-tank also removes the OEM filter, which means you need to add an external one to maintain proper filtration.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 05-29-2025, 03:22 PM   #14
SOCAL.M6.ZLE
Exactly... and I did not like the placement of the Katch solution on the firewall, so I made this bracket to hide under the car
