Old 05-17-2025, 06:12 AM   #1
veaceonee
Drives: 2016 Camaro SS
Magnuson coolant reservoir cap stuck
I'm probably going to get flamed for this, but here goes. Was trying to check the coolant level on my supercharger (Magnuson Heartbeat) reservoir and the cap is stuck. I can't push down and twist, or pull or squeeze. Tried applying "extra force" and it made a scary noise, immediately stopped. Anyone else have this problem? Probably just being to cautious. TIA
veaceonee is offline   Reply With Quote
Old 05-17-2025, 07:59 AM   #2
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Did you try tapping on it?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 05-17-2025, 08:25 AM   #3
veaceonee
yes. Still wont move.
Old 05-17-2025, 08:32 AM   #4
It's a standard hard plastic screw-on cap, not the pushdown type, someone must have tightened it real hard. I'd try an oil filter wrench or a large crescent wrench, very carefully of course.
Old 05-17-2025, 11:34 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If it breaks, it's a standard FORD reservoir cap, confirmed by Maggie Tech line. Use some big channel locks with a rag and it should come off. Dorman 52408.
'20 ZL1 Black "Fury"
Old 05-17-2025, 07:42 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Gabe, owner of GMS and Sponsor here, looks like he just released a coolant bottle kit, in case you need one
Old 05-18-2025, 08:33 AM   #7
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
That Edelbrock bottle still does not offer bleeding air out of the system automatically as it uses a 16psi cap designed for pressurized engine coolant at temps over 212º! If your SC coolant is that hot, you've already lost the battle... and as you & I have discussed, my emails to become a supporter of this site to recommend parts that are actually track-proven to work and not just band-aids, remains unanswered. I know this coolant bottle system doesn't work because I designed this a year ago, Gabe copied it and through my actual road course track testing I did, found it NOT to WORK in keeping all the air out.
A true coolant expansion tank MUST be higher than anything else in the system, it must not only have an unrestricted path from the supercharger but allow an internal chamber for separation of air from the fluid, similar to an Air-Oil separator. Furthermore, you need to have a positive bleed line from the SCHX so any bubbles that have parked themselves in the higher parts of the heat exchanger, can be pulled to the reservoir without passing through the SC bricks. Just adding a fender tank with an o-ring cap and full sealing, does not help bubbles migrate and dissipate... that is the job of a pressure flexible cap.
As everything I have shared over the past two years as a member here, I offer my experience for free, based on testing on the track and street from the knowledge of decades as a fluid dynamics Engineer for both Aviation and Marine systems.
Patriot Motorsports USA is offline   Reply With Quote
Old 05-18-2025, 10:13 AM   #8
veaceonee
Got the lid off. Holy crap was it tight! And of course it was low, so topped it up and all is right in the world once again.
Old 05-18-2025, 01:40 PM   #9
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Today at WOT the coolant resevoir valve from my supercharger openend.
At 125 mph roughly 0.7 gallon coolant splashed out of the hood on my windshield.
16 psi imo. is way too low on these valves.
I refilled and bleed the system from air and all fine again. No hose leak or so.
https://youtu.be/cQjDq0e5KIs
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 05-18-2025, 01:56 PM   #10
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
FYI if your pump senses an air bubble it’ll stop momentarily, and your system will flash to steam causing your issue.
Old 05-18-2025, 02:07 PM   #11
SpeZ
SpeZ's Avatar
The cwa150 does not turn off. It has no internal logic.
But the explanation seems true, it somehow went off and some fluid started to boil.
Because even with the cap open, filling resevoir entirely and closing it, turning off the pump results to trigger the overpressure valve.
The fluid level decreases with pump running and increases again if it stops. The fluid pressure together with slight drainback triggers the overpressure valve. So I used only a half filled resevoir and had no issues until once today. Even on race track it was okay.
Old 05-18-2025, 02:42 PM   #12
Joshinator99
Moderator
I have the same pump and had mistakenly ran the wrong size fuse…so I found out the hard way what happens when the pump stops lol
