Old 05-13-2025, 06:05 PM   #1
2018zl1-1le
Drives: Zl1 Camaro
supercharger coolant pump
Does the pump for the supercharger coolant always run or does something trigger it to turn on? And if something triggers it would it be bad to just have it run all the time?
2018 Zl1 1le 6speed
2” Kooks headers ,green cats full exhaust
JLT intake, BTR Stage 2 cam,Mighty Mouse catch can
Innovations west damper 9.25” lower
107mm throttle body, Mpi lid, flex fuel
Full SPL rear suspension, DSX twin intank pumps
2018zl1-1le is offline   Reply With Quote
Old 05-13-2025, 07:00 PM   #2
SWFLZL1
Drives: 2022 ZL1
Pretty sure it runs all the time the engine is running.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 05-14-2025, 03:27 PM   #3
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
It is a "Key On" device and not controlled with a command in HPTuners. You will get a soft code if the Canbus determines the pump is not running or the relay has failed.
Patriot Motorsports USA is offline   Reply With Quote
Old 05-17-2025, 06:48 PM   #4
2018zl1-1le
Drives: Zl1 Camaro
So another question can you run a trunk coolant tank with the factory pump? Or do you need to run a pump by the trunk coolant tank and bypass the factory one or do you run both?
2018 Zl1 1le 6speed
Old 05-17-2025, 07:15 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
You only need a trunk tank if you’re running 93 octane (and perhaps an Interchiller). You don’t need either if you’re running E85. E needs heat to vaporize properly and will make more power than a trunk tank..by a fair bit.
If you do decide to run a trunk tank, you either need to replace the weak factory pump with something like a CWA150, or add another factory pump to move the water from the back of the car to the front (so you’d run both pumps in the case).
