Old 04-18-2025, 09:32 PM   #1
tmp123
Drives: Chevrolet Camaro ZL1
Oil change -first startup noise
So I changed the oil on my zl1 after it sat in the garage all winter.
Stupid me I did not run it before the oil drain.
I pre filled the oil filter and poured the new oil in.
At startup I heard a knock noise for a second or two. It freaked me out.
Cars runs fine and noise free.
I dont remember hearing this before.
Did this happen to anyone here?
Thanks in advance
tmp123 is offline   Reply With Quote
Old 04-18-2025, 11:03 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Thanks in advance
If you pre-filled the oil filter (all the way) you should be fine... I know it takes 4 or 5 "fills" of the oil filter to actually be fully pre-filled (takes time for it to flow past the media), fill the filter, wait a bit and fill it again, keep filling it until it doesn't take any more oil...
2SS Capt is online now   Reply With Quote
Old 04-19-2025, 07:11 AM   #3
SWFLZL1
Drives: 2022 ZL1
Thanks in advance
I’m sure all will be okay, just needed to build pressure for a split second. You should hear my Duramax, since it’s first oil change, it’s horrible sounding on a first start.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 04-19-2025, 11:33 AM   #4
Haha, I'm not sure that gave him the peace of mind you intended
Old 04-19-2025, 11:34 AM   #5
Thanks in advance
Nope, I always drive the car first, then wait for the oil to cool to a temp that my hand and arm can handle in case I fumble the drain plug.
Old 04-19-2025, 05:49 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Probably just the chain tensioners filling back up with oil for a few seconds after the long winter's nap.
Old 04-19-2025, 08:24 PM   #7
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
You can always hold down accelerator pedal (flood clear mode) and run the starter to build oil pressure after doing an oil change...
LiqTenExp is online now   Reply With Quote
Old 04-20-2025, 08:54 PM   #8
tmp123
I would love to but its a 6 speed manual, i dont have 3 legs lol
Old 04-20-2025, 09:23 PM   #9
Camfab
Drives: ‘23 ZL1-1LE
This 100%
Camfab is offline   Reply With Quote
Old 04-21-2025, 06:20 AM   #10
NashZL1
Drives: 2022 Camaro ZL1
I drive my Mercedes SL450 every two weeks or so. The rattle at startup after it sits is normal... apparently. Goes away in 2 seconds. Just takes a bit till the oil pressure and flow come up.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2018 Porsche 718 Cayman GTS
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2024 Honda Civic Touring
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 04-24-2025, 03:06 AM   #11
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf R
Has anyone actually tried this? I heard about it and tried it in my GTI… for about 2 seconds until it skyrocketed to 3k rpm
Not my best moment.
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG
PowerDemon is offline   Reply With Quote
Old 05-03-2025, 08:34 PM   #12
tmp123
I changed the oil and no glitter in oil. No noise at startup.
Next , the oil filter will come apart to see if any debris is visible.
Also I sent out the oil to be tested.
SO far so good
