![]() Drives: 2017 Chevy Camaro 2ss Join Date: Apr 2025
Drop in pistons and rods
I’m planning on doing a magnuson 2650 build on my car but im not sure which direction to go engine wise. I was planning on doing a 416 Darton sleeved block but after getting quotes, I’m leaning towards going drop on pistons and rods as this would free up money to go towards building the trans and doing the xdi high pressure fuel system.
My question is, can the stock block handle 1100whp, Which is what I’m projecting to make? Has anyone made over 1100hp on just the drop in gpi stuff? |
#2 | |
![]() Drives: Chevy Camaro Join Date: Sep 2022
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels. 1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake |
#3 | |
Moderator
![]() Gotta get the fueling and tuning right though… Edit: agree with jlaudio11
![]() Drives: 18 Camaro 2SS Join Date: Jul 2022
I've been running stock block and crank with callies rods and diamond pistons for 7000 street miles and 100's of 1/4 miles passes with almost 1k rwhp with no problems. I probably just jinks my self.
#5 | |
Moderator
![]() Drives: 2021 Camaro 2SS Convertible Join Date: Jan 2025
Did any of you machine your stock block, or you just swapped rods and pistons with drop-ins and banged away on it?
#7 |
Moderator
No machine work was needed.
#8 | |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
Obviously during tear down, if anything looks excessively worn or damaged, it needs to go into the shop. Mileage counts, too. If everything looks good and miles are relatively low I'd feel good about a straight drop-in.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
#9 | |
I want to add a Whipple 3.0 down the road, and have heard that the innards are squirrely under boost. Been talking to some of the GPI boys about it all. |
| Tags |
| gpi |
