Old 04-09-2025, 06:37 AM   #1
Drnick
Drives: 22’ ZL1
Recall for body control module??
As stated above, what’s this recall about?
BCM ??
Drnick is offline   Reply With Quote
Old 04-09-2025, 06:53 AM   #2
z28pat
z28pat's Avatar
Drives: 2002 z28, 2023 Zl1
I just did it , it only says a security issue. The service advisor didn’t have or didn’t share anything else about it , took about and hour and a half to do
2002 z28
2023 zl1
z28pat is offline   Reply With Quote
Old 04-09-2025, 07:06 AM   #3
Deacon Blues
Drives: 2024 Camaro 1SS M6
There are at least two other threads on this. Nobody knows exactly what it does, but it is suspected to alleviate (but not completely solve) the OBD port key generation thefts.
Deacon Blues is offline   Reply With Quote
Old 04-09-2025, 07:37 AM   #4
Drnick
Drives: 22’ ZL1
I just called the 800 # and the dealership near me
Both are totally clueless!!! Other than it’s an update
To the BCM!! Have no idea what it actually updates!
Is it some sort of update for security purposes? And if
So, what is it updating!!!!
Old 04-09-2025, 07:42 AM   #5
Deacon Blues
https://www.camaro6.com/forums/showthread.php?t=633088
Old 04-09-2025, 07:44 AM   #6
Deacon Blues
Longer discussion here: https://www.camaro6.com/forums/showthread.php?t=632684
Old 04-09-2025, 01:59 PM   #7
triggerjerk
Drives: 2023 Camaro ZL1
I had this done today. In and out in a little over a half hour. I think the actual programming was more like 20 minutes.
Afterwards I had to reset my ambient lighting setting and bluetooth was picky for a minute but I think that is it. I haven't really explored all of the settings so if there were changes there I can't say.
triggerjerk is offline   Reply With Quote
Old 04-09-2025, 02:58 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
Do they only flash the BCM?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
JSH is online now   Reply With Quote
Old 04-09-2025, 03:05 PM   #9
triggerjerk
I think that is the case. The invoice says "Reprogrammed BCM".
There are also a few "WCC" codes, whatever those are.
Old 04-15-2025, 05:50 AM   #10
Brettallen59
Brettallen59's Avatar
Drives: 2023 ZL1 - 1969 SS396
I have an appointment for Friday. They told me 4-6 Hours. Since you all are seeing shorter times, I might just hang out for an hour and see what happens. But here is my main concern; I have a buddy at work that had it done on his wife's Suburban - Same "BCM Re-program". Started having problems with On-Star 4 weeks in. Now he is seeing all sensors freaking out and On-Star failing. He told me DO NOT do it! I'm reaching out here to see if there are any issues. I think I'll wait for another 30 days and check in here periodically.
B...
2023 Code ZL1 1AL37 - Track Pack PPF - Jade Obsidian Graphene Pro Ceramic Coating
1969 Code X66 SS396 - RS Conversion - Holley Terminator TB w/ HP ECU EFI - TKO600 - 3.73 Posi.
Brettallen59 is offline   Reply With Quote
Old 04-15-2025, 05:52 AM   #11
Z OH 6
Drives: 2024 CT5-V Blackwing
B...
Doubt it has anything to do with the BCM update. He's got a separate issue.
Old 04-15-2025, 05:57 AM   #12
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
That's not likely due to the reprogram. There have been many successful reprograms already, and I haven't seen any reports of issues. Sounds like your friend should check his battery. A low battery would cause these issues.
My Camaro Journal
Old 04-15-2025, 06:01 PM   #13
Brettallen59
Okay, very relieved and yes, I'll let him know and have him check his battery. Thanks!
Brett....
Old 04-16-2025, 11:31 AM   #14
JSH
JSH's Avatar
Drives: '20 ZLE
I don't trust my dealer to do anything
2020 ZL1LE A10.
