Old 04-01-2025, 11:15 AM   #1
Dexterpoole2014
Drives: 2022 ZL1 A10
Exclamation ZL1 A10 whistling/whirring sound at idle
Hey everyone,
In the videos posted below you will see the sound my zl1 is making. This only happens at idle. I am still trying to get a better video but this sound of course cannot be replicated in my driveway. So in a drive thru at Starbucks is the best I have. One clip shows a whistling sound and another shows a type of squeaking that a bad tricycle makes or something.
I have pulled off the supercharger belt and spun all the pulleys by hand. Only 1 of them shows a slight amount of "play".
https://youtu.be/EgWIlneCZtQ?si=0v34rGY5UvnEcGst
https://youtu.be/EgWIlneCZtQ?si=nQ70Y0kIjWj7gf5J
https://youtube.com/shorts/8bLRrsqTM...OH2JN7fE7JqLl9
(Current) 2022 ZL1 A10 Rotofab big gulp, 2" speed engineering headers, Borla Atak , ECM/TCM pray performance tuning
(SOLD) 2019 SS 1LE (manual) FBO Pray Performance dyno tuning
(SOLD) 2018 zl1 a10 mbrp catback and pray performance dyno tune 641/670
(SOLD) 2016 SS FBO Pray performance Remote Tuning
Dexterpoole2014 is offline   Reply With Quote
Old 04-03-2025, 11:34 PM   #2
SoCal Smith
SoCal Smith's Avatar
Drives: 2019 Camaro ZL1 1LE A10
Is it still under warranty? First owner?
Try it with the AC off, see if that is causing it come and go. The play in the video looked normal.
How did the tensioner feel when you moved it to get the belt off? no leak? bolts are tight on it?
SoCal Smith is offline   Reply With Quote
Old 04-04-2025, 08:00 AM   #3
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Any change the sound quieting foam was removed from under to blower, could it be the injectors making the noise?
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 04-04-2025, 10:39 AM   #4
Dexterpoole2014
None of the foam has been removed. Also, yeah the car is under warranty, but I do have a tune on it so I assume they will see that and deny it. I can pay for whatever tho lol it's going on a lift tomorrow when I change the oil and I'll check all up underneath as well.
Old 04-04-2025, 12:03 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Did it start after you installed the RF? Your only mods' are in the signature, plus a toon? As asked above - first owner?
'20 ZL1 Black "Fury"
Old 04-04-2025, 12:15 PM   #6
Dexterpoole2014
Im the 2nd owner. Got it with 3k miles now has 19k miles. Only thing changed was the tune, but the tune has been on it for a couple months. This started a few days ago.
Old 04-04-2025, 02:46 PM   #7
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Just sounds like normal rotofab noise to me in the one video, FWIW.
Mods being installed-
Old 04-07-2025, 09:01 AM   #8
Dexterpoole2014
UPDATE:
so i am very sure this was what was making the sound. I was able to eventually get underneath the car WHILE it was making the sound. ended up being the rubber piece slipping off of the fuel line and the exhaust clamp was rubbing and "scoring" it sometimes to where it would sound like a rotating part was squeaking. its been a couple days now and no more noises!
https://youtu.be/22-d_xiQ65Y?si=Maos4qy9lZQ4QlhV
Old 04-07-2025, 11:04 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That might be one of the diff' cooler lines, but regardless - good work on sorting it out.
Way to go, dealership tech'...
Old 04-07-2025, 06:45 PM   #10
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Yikes!
Old 04-08-2025, 09:39 AM   #11
2023_ZL1-AUTO
Drives: 2023 ZL1
Originally Posted by Dexterpoole2014 View Post
UPDATE:
WAY TO GO! Great job of troubleshooting !!!
Old 04-13-2025, 04:05 PM   #12
Dexterpoole2014
I hate to say it, but it freaking came back. Sound is back and it was not the rubber part that slipped off
Old 04-14-2025, 12:22 PM   #13
AZ_1LE
Drives: 2019 ZL1 1LE
Why in the hell would GM run a fuel line THAT close to the exhaust??????
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 06-01-2025, 10:55 AM   #14
Dexterpoole2014
Got another UPDATE
I'm very sure that the rattle came from that fuel line BUT I checked that fuel line and it is still not making contact. So sliding that rubber part over to keep the metal from contacting worked.
On the other hand, I have sort of been able to pinpoint where the sound is coming from and it's under the car near that SECONDARY catalytic converter and NOT the primary on the driver side. Not sure if something broke loose inside of it. But im not worried about it now because I will be getting headers put on in a few weeks.
engine noise, engine sounds, pulley sound
