Old 03-29-2025, 07:00 AM   #1
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Magnaride delete control module
I just deleted magnaride and installed DSSV's on my 2022 SS 1LE. I bought a suspension control module off of eBay (Part# 84214461) and it was not the right one. I read on this forum in a few different posts that this was the correct part number. It seems they are all the same part # but are just programmed differently. How do I know which module to buy if they are all the same part number? If anyone has one for sale that is the correct one, LMK.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 03-29-2025, 07:12 AM   #2
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Same situation for me. Currently it shows "service suspension" codes even tho I connected 100W3O resistors.
Theoretically the control module must be from a car which had no magnetic ride suspension.
The problem is, pretty much all modules you can buy are from vehicles which had magnetic ride.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 03-29-2025, 12:01 PM   #3
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Yup, just need to find one from a car w/o magride.
I called a parts yard (Day's) and asked them for one, but you can also check ebay and either ask the seller (they probably have no clue) or check the VIN of the vehicle it came from, the VIN is often given in the listing.
If you have the correct non-magride module you no longer need to use resistors. just coil up the electrical leads and zip tie them down somewhere.
Old 03-29-2025, 12:39 PM   #4
Rapid_blue_zl1_22
What are you looking for in the vin to know it is the correct one?
Old 03-29-2025, 12:55 PM   #5
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
If it’s a 2020+ car, you can get the window sticker from the VIN showing the options and determine if it has MRC there.
https://windowstickerlookup.com/
2016 1LT v6
- Totaled
Happiness: Infinite
Old 03-29-2025, 03:30 PM   #6
SpeZ
SpeZ's Avatar
Update: my DIY solution works. One connector wasnt seated properly.
You can build your own if you got the tools or know someone.
Parts:
15 AWG wire
8x 1718760-1
4x 1-1703498-1
4x 100W 3 Ohm resistor
and maybe some shrimp tubes
In total it's like 15-20$
Old 03-29-2025, 03:45 PM   #7
DaveC113
DaveC113's Avatar
Run the vin using a vin lookup tool and it'll show options
Old 03-29-2025, 05:13 PM   #8
Rapid_blue_zl1_22
I checked every single one with a vin listed on ebay that was 2020+. Nothing available right now.
Old 03-29-2025, 07:24 PM   #9
DaveC113
DaveC113's Avatar
That's too bad, I think '16+ should work. Maybe others, that module is likely the same as caddies and even trucks. It's the same part for all cars with the same modulem, then the dealer programs it for the specific car.
Old 03-29-2025, 09:20 PM   #10
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
Anyone know if it is possible to reprogram the suspension module?
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 05-10-2025, 02:02 PM   #11
tecmec
tecmec's Avatar
Drives: 2016 2SS
Do the non-magnaride cars still have or use the suspension position sensors?
I’m planning on switching to coilovers, but I have developed a custom AIM profile that monitors the suspension position sensors, and I’d like to keep that. Does anyone know if the non magnaride cars came with the position sensors? Maybe PTM on the ZLE still cared/monitored the position for the eLSD or something?
tecmec is offline   Reply With Quote
Old 05-10-2025, 04:56 PM   #12
Baddawg53
Drives: 17 hyper blue 2SS M6
I'm pretty confident that those sensors are specific to mag ride shocks.
Baddawg53 is offline   Reply With Quote
Old 05-15-2025, 10:39 AM   #13
tecmec
tecmec's Avatar
Drives: 2016 2SS
That’s my guess as well. What the heck does a non-mag-ride car need a suspension control module for though then?
Old 05-16-2025, 07:05 AM   #14
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I bought a module off eBay from a ZLE. Be sure to verify. Can't go by the part number.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
