Old 03-22-2025, 09:20 PM   #1
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
Question running wire from engine bay to passenger side interior
I did a search, with Google because the other search box is useless on this site, and did not see anyone do this.
I want to run power, + & -, into the passenger side of the car and add a fuse block in the same area as the interior light control box(glove box area).
Looking at the options, there is the positive cable grommet I could poke a hole in, not my ideal location/choice.
Looking more, it appears that there is a body cap located on the body above the door harness grommet. It is NOT a grommet, just a plastic plug so I would replace that with an actual grommet.
The path into this hole seems to be rather simple. There is no metal that has to be drilled, but a piece of fiberboard(no idea what to call it) that separates the engine bay from the inner fender door hinge area.
It appears the door opening/closing does not come close to the wire, if run this way.
Has anyone penetrated the firewall on the passenger side any other way?
It does not appear there is an easy access to the firewall, from either side, to drill a new hole.
I do not want to run to the driver side and then back over if at all possible.
Thanks!!!
2018 Blue 1LE is offline   Reply With Quote
Old 03-22-2025, 11:26 PM   #2
Justcruising
Justcruising's Avatar
Drives: 2019 Chevrolet Camaro 2SS A10
Can you just use the terminals or fuse location in the trunk to get power from? That way you can just run the wires along side of the power cable inside of the car, I might be missing something but it’s just a thought.
2019 Camaro 2SS A10 Procharged, Flexfuel, with Stainless Works headers back to Legend series mufflers.
Justcruising is offline   Reply With Quote
Old 03-23-2025, 12:12 AM   #3
2018 Blue 1LE
How is that any easier?
Old 03-23-2025, 12:47 AM   #4
Justcruising
Im not saying it is, I am just spitballing so to speak, but if you ran wires from the trunk you wouldn’t have to worry about pinch points and water intrusion which causes corrosion, I was just trying to come up with a safer/other option.
Old 03-23-2025, 01:01 AM   #5
2018 Blue 1LE
Okay, thanks.
At this point, more work than doing it from the front.
Pinch point is non existent, the hole is there from the factory and just needs the proper grommet, there are extra studs on the positive connection and it is a shorter run.
Old 03-23-2025, 04:14 AM   #6
Justcruising
gotcha if I may ask, what are you going to power off of the fuse box you are wanting install? Might be a good project some of us on the forum could use
Old 03-23-2025, 08:08 AM   #7
Have you considered using the sound tube hole in the firewall? It's towards the middle of the engine bay on the driver side, see step 4 and figures 5 and 6 in this doc: https://www.phastekperformance.com/c...6STDK_Inst.pdf
Old 03-23-2025, 11:44 AM   #8
2018 Blue 1LE
I have considered it.
Old 03-23-2025, 11:58 AM   #9
2018 Blue 1LE
Instead of all these taps or harnesses, going to use it for radar, dash cam, alternative security device power or .
It just seems like an easy spot to have a power source.
Old 03-23-2025, 01:39 PM   #10
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
If you change your mind, here’s a route to the rear fuse box I use
2016 1LT v6
- Totaled
Happiness: Infinite
Old 03-23-2025, 08:36 PM   #11
2018 Blue 1LE
Thanks
Old 05-06-2025, 12:54 PM   #12
MANNAXMAN
MANNAXMAN's Avatar
Most people run a wire through the cap in the door pillar because it's the easiest way. Forum member overdriv ran wires through the firewall grommet shown in your last picture. See his How I hardwired my Dashcam thread.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
