Old 03-22-2025, 07:47 PM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
PWR Supercharger Bricks
Hey guys, was curious who have these installed? If so, can you provide some feedback? If not... why not?
Old 03-22-2025, 08:47 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Sell your blower. Take the money you get and add the $1700 you would have wasted on bricks. Then add the $1500 you would need to pay Kong for porting. Now you’re nearly at what you need to buy a 2650 or 3.0 blower with substantially better cooling than any modified LT4 blower. And WAY more power potential too.
Old 03-22-2025, 11:33 PM   #3
SOCAL.M6.ZLE
I'm with you.... I always thought $1,700 was wayyyy too much for this product. I know they have sold quite a few of them, I just haven't met someone who has them...
Old 03-23-2025, 04:36 AM   #4
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Agreed. The bricks are just too small, there is nothing you can do to make them dissipate enough heat. A chiller would be better money spent than upgraded bricks.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 03-23-2025, 07:13 AM   #5
Joshinator99
Moderator
The rotor pack is too inefficient at greater than stock airflow, so that’s the root cause. GM originally had the rotor pack sized at 1640 to meet the 650 HP target. When it didn’t reach it, Eaton elongated the pack a tick and ended at 1740. But elongating the pack sucks for efficiency. Porting it helps get air to it better but the rotor pack is too small to efficiently get air moved at high power levels. The 2650 & 3.0 rotor packs simply move higher volumes of air at much lower discharge air temps…then they blend in massive bricks to boot. Win win.
Old 03-23-2025, 10:07 AM   #6
SOCAL.M6.ZLE
I agree... the OEM Bricks are too small... there is room in the3 casting to make them larger... PWR made them what appears to be 25% taller, and I have heard from for than one tuner that they made more power and had lower IAT's with the PWR bricks. The issue is the cost as everyone pointed out.
So that begs the question... if someone were to make a brick that had 75% for surface area, showed improvements in IAT's... and was at or below the $1,000 mark... I think that would be alot more appealing, no?
Old 03-23-2025, 01:49 PM   #7
triggerjerk
Drives: 2023 Camaro ZL1
Cost aside, wouldn't the pwr bricks and a ported blower make decent gains for stealth/no tune mods?
triggerjerk is offline   Reply With Quote
Old 03-24-2025, 06:34 AM   #8
clg82
Drives: 2020 Camaro ZL1
Sell your blower. )
Stooooppppppp he's got nearly 70K in that tiny blower already!!!!
Old 03-24-2025, 06:49 AM   #9
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I asked about this a while back and no one seemed to like them. Everyone said just upgrade the supercharger. I for one l, would love to see this!
Old 03-24-2025, 08:23 AM   #10
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Gabe, as you are aware, my FI Interchillers Stage 2 is kicking AZZ and working phenomenal with my Kong X-port blower that is running 2.3" upper and 9.45" lower, max boost so far since getting the car back from Katech 23.4psi !!! Just trying to keep the little 1.7L Eaton (R1740) A LIVE !!! Just remember, anyone can bolt on a 2650... just say'n !!!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 03-24-2025, 09:13 AM   #11
SOCAL.M6.ZLE
Same here... listening to a few that tested them, the OWR's do work, but the price point makes this a very hard sell.... my intuition is that we have enough room in the blower casing and lid to increase the OEM size to approximately. 75% more surface area. Even taler than the PWR's.
Expecting testing to confirm this.
If we can get the size right, and reliable decrease in IAT.s which seem inevitable with 75% more fin area... and our manufacturing partner can help us get these to a target of $1k or less... I think this will be a solid upgrade for 1.7L purists like me and you...
Stay tuned. Loving the discussion.
Old 03-24-2025, 09:17 AM   #12
SOCAL.M6.ZLE
You are such a dork HAHAHA
I do love the 1.7L blower... and love seeing the evolution the industry has helped it create. (porting, lids, bricks, etc)
Old 03-24-2025, 09:48 AM   #13
clg82
