![]() Drives: 2016 SS Join Date: Oct 2019
Programming memory seats. Door button vs. Key Fob.
When I bought my car, the dealer joked about how the previous owner was a little old lady, and the key fob was programmed to put the seat super high and close the wheel. Almost got crushed when I got in!!!!! It was funny, we laughed, all good, I bought the car, turned off the auto recall which ties the seat to the fob, and programmed my seat. Push set til it beeps, Hold the 1 or 2 until 2 beeps. All good.
Today, the dealer turned the auto recall back on, since the service tech adjusted the seat. He said it would go right back to my settings when I got it. No big deal, I don't use the feature, but no biggie. When I got it and cranked it up, it defaulted back to the previous owners settings, super close to the wheel! Long story short, I can obviously turn OFF auto recall, and I can re-set the door button, but I can NOT figure out how to get the key fob to recognize MY settings, and not go back to the previous owner's settings. Thoughts? |
![]() Drives: 2017 Hyper Blue Camaro 2SS Join Date: Aug 2016
Did you try the other key fob?
![]() Drives: 2000 GMPPSV SS & 2020 2SS Join Date: Jul 2017
That thing when it goes all the way up isn't a setting from the old lady - it's to allow rear seat passengers out.
#4 | |
....so I got it figured out. I had originally been using Fob2, so the other day when this happened, I kept programming button number 2. .....I'd move the seat while driving, press button 2 and it went back to my programmed spot. When I'd go to get back in, it was reading what I THOUGHT was fob 2. It was not. It was fob 1. ....at some point I must have started using Fob 1. Later that day I got both fobs out and got it figured out and programmed them both. |
![]() Drives: 2021 3LT RS A10 Join Date: Nov 2021
#6 | |
One can make the car use it automatically when you kill the engine and open the door (seat moves from its current position to the exit position) and when you close the door and start the engine (seat moves from exit position to memory position 1or 2, depending on which fob you're using or last memory position when both fobs are in the vehicle).
#7 | |
With the driver still in the seat!?!?!?! ![]()
#8 |
Long hauler
2016 1LT v6 - Totaled Happiness: Infinite |
#9 |
Yes, that's what it's for, to allow the driver to get out of the seat a bit easier. Typically, people prefer to have the seat move back and up, so they don't have to lift themselves up off the floor from under the steering wheel.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#10 |
It's not the exit. Exit is off. ...and it wasn't doing this when I got OUT, it was when I get IN. But regardless, it's fixed. Issue was I mixed up which fob was which, -which is why the button wasn't reprogramming the fob. Wrong fob in hand!
