Well guys, CNRED took a hit last weekend. My father took her out and got a bit over confident, got sideways and hit a curb at about 60 mph. Side airbags deployed, the right side rear suspension is completely trashed, rear wheel is shot, seatbelts locked, and there was parts scattered at the scene from the underbody. Passenger door doesn't line up any more.
The yard that has the car is claiming they think it is not a total loss, insurance believes it is. If anyone has any advice on dealing with Progressive it is completely appreciated. |
Dad is ok! forgot to mention the most important detail!!
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Well my first ZL1 took substantial damage like that as well. Took it to a local reputable body shop and they wouldn't use anything BUT OEM GM parts so they ended up totaling it. Had a check in my hand about 3 weeks later from GEICO. I can only honestly comment on the damage part not the insurance part. Good luck either way.
![]() Drives: 2018 HYPER METALLIC BLUE ZL1 Join Date: Mar 2021
Sorry about the car! but glad your dad is ok, and i have progressive and i got rear ended coming home from vegas but in a 2014 maxima took it to crash champions and same as clg82 they wanted to use factory parts and progressive didnt wanna deal with the hassle they just cut me a check within 3 days but gave they gave me the option to buy it back. i hope this helps.
![]() Drives: 2023 Camaro ZL1 Join Date: Jan 2016
That's rough. Almost happened to me once after hammering the gas while not completely through a turn on cold tires (with ptm in race mode so no nannies oops). Luckily, luckily, the road was so wide and traffic so light I missed any other cars or curbs. Tough lesson to learn but glad your pop is ok and you didn't hit anything/one else.
![]() ![]() ![]() Drives: 24 LT1 M Join Date: Oct 2015
Summer tires in snow...? Obviously things won't turn out well.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30 |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
![]() Even worse, they are more race tires than most summer tires.
"KEEP THE FAITH"-Fbodfather |
#8 |
Sarcasm loading --------
I'm thinking its totaled..If the doors and fenders dont line up anymore its likely the unibody is twisted.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#9 |
That may be true, the justification from my insurance company was that the suspension components alone front and rear after my side impact were crazy expensive. Not even sure they got to the subframe or unibody before they totaled mine.
#10 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Sorry to see this happen and glad everyone is ok, I can imagine. If it's totaled, maybe see about buying it from the insurance company and then possibly start working on a full out drag car for the track?
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#11 |
Appreciate all the info fellas, this was is a tough one car had a new motor in it and was going strong, was planning on putting another 100k on her.
As for the tires, put 85,000 miles on it though 4 winters with no issue. Its about knowing what you got and the limits. Practicality is another story.... Loved that car.... |
#12 |
If I had the cash this would turn into a race car!
#13 |
My vote is take the money and put it towards a CT5 V Blackwing.
#14 | |
I'm glad everyone is okay, but it's quite sad to see another one of these rare beauties bite the dust.
