Old 02-18-2025, 11:53 AM   #1
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
For those that need to pull the engine
Hey Guys,
Posted this in the DIY section but it's more applicable to the ZL1 so figured I'd put it up here also. Made a video on how to pull the motor out the top for those that need to get it out for one reason or another and like to do your own work. Hope this helps!
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Old 02-18-2025, 12:42 PM   #2
SWFLZL1
Drives: 2022 ZL1
Nice detailed video.
SWFLZL1 is offline   Reply With Quote
Old 02-18-2025, 03:43 PM   #3
Evansa22
Evansa22's Avatar
Thank you, try to do my best with them. Like adding the service manual pages in case I don't get the best shot and it let's you know how it's supposed to be done according to GM.
Old 02-18-2025, 03:52 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Very nice, I will check it out.
Old 02-19-2025, 08:35 AM   #5
Future1LE
Drives: 2020 Chevy Camaro ZL1 1LE
Hey, since your engine is out. Can you help me with a picture or video. My belt from my super charger broke and cut a few wires. I believe its the Camshaft position sensor harness. Can you grab me a picture or video of how that harness look and is routed? I am referring to the wire harness on the front cover...incase I got the name from lol..
Also if anyone know the part number for that harness and can share, that would be awesome!
Thank you
Future1LE is offline   Reply With Quote
Old 02-19-2025, 08:59 AM   #6
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Great job Aaron, this is going to help alot of people for sure! great work!!
Old 02-19-2025, 10:38 AM   #7
beowulf556
Drives: Camaro SS 1LE M6
Some serious talent pulling an engine out by yourself! Well done!
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 02-19-2025, 10:58 AM   #8
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Awesome video, and very timely for me! Many thanks!!
Mods being installed-
Old 02-19-2025, 11:17 AM   #9
Ringmaster72
Drives: Chevrolet Camaro
FUTURE1LE in regards to the harness......
I went through this last year. I had a belt issue destroy my harness and had a hard time finding the part. I used this part number: 12734111. If I remember there was slight difference but it worked without any wire changes. I think the "bracket" was slightly different. Here is the exact one I used. I also have the TSP DOD delete timing cover, so it is slightly different than stock and does need that plug.
https://www.ebay.com/itm/296886665875
Ringmaster72 is offline   Reply With Quote
Old 02-19-2025, 11:53 AM   #10
Future1LE
Thanks for that information! My timing cover still stock. I actually did found that part number as well when I was searching this morning and saw that it was replaced by Part number 12712016. Just based off part picture, I think it should be the right part. Was it hard to replaced? How long do you guess it took you?
Old 02-19-2025, 11:55 AM   #11
Ringmaster72
It wasnt bad, it unplugs on the drivers side by the oil pan. Worst part was the goddamn stretch ac belt
Old 02-19-2025, 01:37 PM   #12
Evansa22
Evansa22's Avatar
I can snap you a picture when I get home if you still need it future1le. Ringmaster called it, on the front of the motor at the bottom. Has a little shield covering it so may be easy to miss.
Old 02-19-2025, 01:38 PM   #13
Evansa22
Evansa22's Avatar
Appreciate the feedback guys
Old 02-19-2025, 01:43 PM   #14
Evansa22
Evansa22's Avatar
Maybe this helps in the meantime time
