Old 02-09-2025, 10:44 PM   #1
Vettethret
Vettethret's Avatar
Drives: 2023 ZL1 1LE
HIGH FLOW CATS...
Hi Fellas,
Are there any out there that actually last? From the posts I have seen on high flow cats, it seems like they fail quite a bit and aren't worth the money, any input?
2023 BMW X4M Competition (Downpipes, Midpipes, Intake, Exhaust, Tune)
2023 ZL1 1LE BC Forged KXO5, 325/345 R888R, KPMF Satin Pearl Wrap, 2650/Heads/Cam/3200 stall/Meth- 918 rhwp/842 rwtq, Girodisc/Carbotech AX6, Race louvers.
Vettethret is offline   Reply With Quote
Old 02-10-2025, 12:23 AM   #2
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Originally Posted by Vettethret View Post
Hi Fellas,
Great question... if you want the good ones, look no further than the GESI UHO 4.5" #85230 rated at 850hp per cat!
I upgraded to these and had them welded in with Vbands after my American Racing HF Cats were heavily folded over after only 3k miles...
Old 02-10-2025, 06:14 AM   #3
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
I concur, I have a set of those as well and they are the best you can get for performance and reliability !!!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 02-10-2025, 06:53 AM   #4
Smokin19
Drives: 19' ZL1 A10, w/pdr
Exactly what happened to my AR HF Cats after 4k. Found them to be loose in the can during oil change. You could bang on them with your fist and hear them rattle. Switched to the GESI high flow 850 cats now.
Smokin19 is offline   Reply With Quote
Old 02-10-2025, 07:43 AM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
My Kooks Green cats from 2020 ended up in my axleback
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 02-10-2025, 09:39 AM   #6
Vettethret
Vettethret's Avatar
Thanks guys, I will look into these now. Going in for a 2650 build in 2 weeks.
Old 02-10-2025, 10:57 AM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
This is the way.
Joshinator99 is online now   Reply With Quote
Old 02-10-2025, 11:10 AM   #8
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
+1 to keep the forum more active. I've got these, too.
Mods being installed-
RobZL1 is online now   Reply With Quote
Old 02-10-2025, 03:39 PM   #9
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
I also have the Gesi. They are still good after 2 years with the mods in my signature. Check out CSP Racing, they sell these Cats with headers in a kit.
Are you getting your mods done at Florida High Performance? I know Erik is a dealer for Harrop.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 02-10-2025, 04:55 PM   #10
SWFLZL1
Drives: 2022 ZL1
Let us know how the build goes, curios to who’s doing your work, I’m in SWFL also.
SWFLZL1 is offline   Reply With Quote
Old 02-10-2025, 07:27 PM   #11
Vettethret
Vettethret's Avatar
I ended up going with Powertech in St Pete. I've been dealing with Joe.
Old 02-10-2025, 07:29 PM   #12
Vettethret
Vettethret's Avatar
Powertech Performance. I don't know what Im going to do for traction. I have a K&N (Previous Owner) and a GT Haus exhaust and spin in 2nd right now with 345 R888rs.
Old 02-10-2025, 08:08 PM   #13
SWFLZL1
Drives: 2022 ZL1
Nice, I’ve talked to Joe before, seems like a great guy. I was originally going to go the 2650 route right out the gate, but decided to go with headers, Roto fab, and e to start. I also have the csp headers and high flow cats (which I think are the gesi’s) and I can tell you traction is a no go in 1st or 2nd. (I have a m6)
Curious about the harrop, he did t offer that as an option when I talked to him. Is it the same price as the Maggie, or is there other benefits over the Maggie? Haven’t heard much about them on a lt4 yet.
Old 02-12-2025, 01:59 PM   #14
Vettethret
Vettethret's Avatar
Ordered! Thanks Guys.
