Old 01-24-2025, 11:23 AM   #1
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Modified LT4 Coolant Pump Relay
Hey everyone,
I started offering this modified relay after seeing the need for it after I did this how-to video on how to bleed the supercharger coolant system of air.
Once I saw the need for the modified relay to make things easier, I started building them, and placed them on my Fourthwall shop. I figured I would post this here for anyone that wants to pick these up and get some power back by bleeding the supercharger cooling system:
Here is the how-to video:
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 01-24-2025, 11:31 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Interesting...
'20 ZL1 Black "Fury"
Old 01-24-2025, 12:10 PM   #3
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Originally Posted by FollowMyLine View Post
Hey everyone,
If you can go with a fender tank like the DSX, no more bleeding !!!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 01-24-2025, 08:47 PM   #4
FollowMyLine
Driver for Hire
Very true, but not everyone wants to go that route. This is a simple solution for a quick purge and bleed, and you can keep the pump running while on track, too.
Luan Zeqollari
YouTube Channel
Old 01-24-2025, 08:59 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Solid thirty pounds of extra weight that is absolutely unnecessary IMO. My car drops IAT during a run with zero storage FYI.
Old 01-24-2025, 09:30 PM   #6
Camfab
Drives: ‘23 ZL1-1LE
Thanks for the video, clear and concise.
Camfab is offline   Reply With Quote
Old 01-25-2025, 06:56 AM   #7
2023_ZL1-AUTO
Drives: 2023 ZL1
I realize all of our cars/builds are different for different applications etc. With mine running 18psi to 20psi of boost at WOT the temps are not so crazy. But, while cruising or in traffic, obviously not in boost. My IAT climbs pretty high on hot summer days. Summer days for a long stretch of time here in Ohio get 98°+. Before the fender tank, my IAT climbed pretty high on those days, 160° to 182°. I added the fender tank and same type days, it stays in the 132° to 148° range. With and without the fender tank, when I ran the car hard the IAT always came down to a reasonable temp. I went with the fender tank due to the high boost I run and the fact that I bought a FI Interchiller Stage 2 kit and it requires one.
Old 01-25-2025, 08:52 AM   #8
Joshinator99
Moderator
Fender tank has nothing to do with heat shedding which is what the OEM setup lacks capacity in. The OEM setup is also prone to being air bound. Both can be fixed without adding 30 pounds of weight. Take a look at Gabe’s website (Griffin Motorsports) for upgraded heat exchangers and much better hose layouts that fix those issues. Interchiller temps are too cold to properly vaporize ethanol FYI. So if you’re stuck on pump gas than I understand the Interchiller choice but E is superior to an Interchiller.
Also you should look at improving your engine’s efficiency. 20 pounds of boost for 784 WHP is a lot and is driving the heat generated by your blower way up.
Old 01-25-2025, 10:58 AM   #9
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
My F.I. Interchiller Stage 1 kit said it required a tank. But it didn't say that when I bought it. I was pissed about it but installed it without the tank anyways. Temps are 80F degree after 10 hours of driving here in HOT Thailand. It's awesome. I will get a tank when I go to the states again next month and it should really get interesting.
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
Bangkok_ZL1 is offline   Reply With Quote
Old 01-25-2025, 01:11 PM   #10
FollowMyLine
Driver for Hire
My pleasure!
Luan Zeqollari
YouTube Channel
Old 01-27-2025, 08:51 PM   #11
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Need one of these to run the fuel pump to drain the tank when swapping fuel.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 01-27-2025, 10:15 PM   #12
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
So how do you keep from triggering the CEL and reduced power with this relay?
Patriot Motorsports USA is offline   Reply With Quote
Old 04-06-2025, 03:32 PM   #13
FollowMyLine
Driver for Hire
Hey sorry, I just saw this since I no longer get notifications from the forums.
We have tested this at 38 minutes of runtime without triggering any CEL or causing issues. This was done at idle, at cruising, and during hard pulls.
We didn't feel it was necessary to test for longer, since most HPDE events are 20-30 minute long sessions. I don't see too many ZL1 or ZL1 1LE cars being used for W2W racing outside of the GT4.R cars, to which I am sure they have a separate cooling solution.
Luan Zeqollari
YouTube Channel
Old 07-02-2025, 11:25 PM   #14
FollowMyLine
Driver for Hire
Intercooler Pump Relays are back in stock!
Luan Zeqollari
YouTube Channel
