Jenny Craig 2025
I need to lose more weight, and I wonder how much the OEM front brake kits weigh on the ZL1/1LE?
I'll also replace the front seats, which weigh around 58# each.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
I think a set of carbon fiber wheels should be in your near future, roughly around $12,000 for a set of (4) 😂😂😂
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
![]() Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC Join Date: Feb 2018
I put the TBM brakes on the front mine and it dropped the weight of the car 80lbs. Didn't weigh it before and after the I did the 15 inch conversion on the rear with the Carlyle brakes.
2019 COPO #32
350 SC 8.25 167MPH 2018 ZL1-NFG-A10 388CI L8T 9.32 147MPH |
Moderator
Did you already ditch the rear seats? Pull the front sway bar?
#5 | |
TBM Brakes, 001-0281-1 Yes, have the rear seat delete, looking at Braun FALCON-S Series Fixed Back Bucket FRP Composite Seats, haven't considered the sway bar,
2020 ZL1LE A10.
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Have you considered CF fenders and hood? A much cheaper route.
#7 |
![]() Drives: 22 LT1 Join Date: Apr 2022
Look in to the new tbm xs3 front brakes. They are more street worthy than the drag brakes and still drop 90% of the weight. Check out Tillett seats if you want some baller stuff. Start by taking most of the weight off the front of car. Plenty of things to delete and remove depending on how far you want to go.
#8 |
The 1LE aero is hurting you far as straight-line performance so delete that. Carbon fiber wheels, TBM brakes, Seats, pull all the carpet in favor of something thinner. Carbon body panels, replace all glass with lexan or whatever the new improved stuff is(forget the name). Have exhaust vbanded so you can drop it just past the resonators, put a panel in place of where the stock muffler would normally reside, so wind doesn't catch the lower part of the rear bumper and act as a parachute...or cut it out. All of this would probably drop the car's ET almost a second in the 1/4. #Because race car!
#9 |
Not after my shop quoted $8k for the two doors!
2020 ZL1LE A10.
#10 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 01-19-2025 at 12:14 PM. |
#11 |
I am seeing fenders for $1400 to $1600 each in CF. Don't know what the wt savings would be.
#12 |
Is yours street and strip?
2020 ZL1LE A10.
#13 |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
Have you thought about moving to a ported maggy 2650? The power difference could alleviate the pain of spending big money on weight savings with a little more power.
#14 | |
When I start considering a bunch of Jenny Craig items, I also consider the cost of 427 SB minus the sale of my 390.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 01-19-2025 at 02:54 PM. |
