Old 01-17-2025, 05:05 PM   #1
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Not sure what direction I want to go with my SS
Current mods:
  • CAI
  • Headers & High Flow Cats
  • X-Pipe and Borla ATAK
  • E85 Tune
  • 1LE Wheel Setup
  • 1LE Brake Setup
Current puts down right at 500 at the wheels on the dot.
I don't know if I want to stay NA and do heads / cam only or go F.I. and if I go F.I. if I should turbo (or twin turbo) or go super charger.
If I go heads and cam, can I go F.I. later or will the cam need to be changed again?
Need4Camaro is offline   Reply With Quote
Old 01-18-2025, 01:37 PM   #2
vince3
Drives: 2022 Vivid Orange LT1-M6
No intake manifold or TB?, which headers and size? Who did the tune?
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 01-18-2025, 03:35 PM   #3
pbSS
Drives: 2023 2SS 1LE
Adding to Vince's questions, it would also depend what your end goals are. Dyno queen or 60-130 monster? Dragstrip beast? You added the 1LE brakes, do you intend to do any road racing? Are you interested in suspension upgrades? You'll also want to consider a drag pack, otherwise all that power is not being put to use.
There's a ton of options depending what you want to do.
Also, since you are so close to "FBO", you might as well add the TB and Intake Manifold in there if you haven't already.
FI would be the best if you are just chasing max power and max dragstrip times. However, nothing quite beats the chop chop of an N/A monster.
pbSS is offline   Reply With Quote
Old 01-18-2025, 04:24 PM   #4
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Originally Posted by Need4Camaro View Post
Current mods:
  • CAI
  • E85 Tune
  • 1LE Wheel Setup
  • 1LE Brake Setup
I REALLY want to know how you do 500rwhp with those mods. Because ya, I barely do that with more mods.
And to answer you question yes you can still go boosted, but you'll need to upgrade internals and fuel system to handle it. If you plan to go boosted the entry boost cam is a Stage 2 boost cam, or higher. You can still boost with a Stage 1 cam like mine though. But in my case I'd have to upgrade the pistons and rods and fuel system to handle it. And depending on how far you boost, you may want to keep an eye on the rear axles and drive shaft especially if you use stickies.
Old 01-18-2025, 04:37 PM   #5
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
+1
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is offline   Reply With Quote
Old 01-18-2025, 05:34 PM   #6
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by SSShark View Post
+1
+2
Old 01-18-2025, 05:53 PM   #7
Need4Camaro
  • Stock IM
  • Stock TB
  • Headers I forgot what brand I went with - I think they are American Racing but I can't remember for sure - Aikman Performance mostly decided that for me.
  • Exhaust - Borla ATAK
It was tuned and dyno'd twice
- 1st by Aikman Performance in Cedar Park TX ~ 460 - 470 between runs
- 2nd and current by Peregrine Speed in Liberty Hill TX ~ 485 - 500 between runs
Luke @ Peregrine Speed used to be a GM Engineer from what I know of him, perhaps he knows something about these tunes that average tuners don't.. that or I have a freak car ..he did seem to do a good job though, and I definitely felt a noticeable difference.
I am thinking I want a road course or track car. Occasional strip is fine, but I would quickly get bored of a car that can't turn.
Old 01-18-2025, 06:48 PM   #8
Judy1le
Drives: 2020 SS 1LE
  • Stock IM
  • Stock TB
As a track guy here, for a track car, you DO NOT want the added heat and weight over the nose of the car that boost brings. Plus, trying to add boost on a car that originally fitted for boost is a pain, and yes the internals need to be upgraded on a LT1 for boost unless it’s low boost and a safe tune. I have a 427 in my SS 1LE and it’s fantastic both street and track. Also personally know guys who have gone from boost back to NA on their dedicated track cars. NA is just easier to manage, maintain and drive for a track car.
Chasing power is a slippery slope, telling you from personal experience ha. If you’re working on a track/road course car, finish going FBO and then do wheels and sticky tires and then get out on track. Power doesn’t make a fast track car, the driver does. I’ve had people who make waaayyyy less power and destroy me on track. Seat time is king.
Judy1le is offline   Reply With Quote
Old 01-18-2025, 10:06 PM   #9
All true, but some people may not care less about overall lap times (aka cornering capabilities) than being f**ing fast in the straightaways, brake pad and tire wear be damned.
Old 01-19-2025, 07:53 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
  • Stock IM
  • Stock TB
Torque & Airflow model, AFR, Injection timing, Spark, Torque Management. If you know how to calibrate these things then there isn't anything else that is going to give you Unicorn power.
When this topic comes up, I always consider Why did the Big 3 automakers put Superchargers on their flagship cars? Imo NA isn't more reliable when you put a good size cam in the engine that requires a lot more valve spring pressures to control the valves. It is just simple physics. The valvetrain will require frequent checks and spring replacement. Cam overlap also makes the car shake, less efficient down low, doesn't drive as nice low speed. Now there are mild head/cam builds you can do that will make reliable power and drive great, but it isn't going to make anywhere near the power a mild supercharged car will. I am not knocking NA either, I like big cube NA builds. You can go milder on the cam and still make excellent power with torque everywhere.
Old 01-19-2025, 08:00 AM   #11
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Happy dyno is the only explanation. Even FBO e85 (which he’s not FBO), does not = 500 whp.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 01-19-2025, 08:05 AM   #12
KingLT1
KingLT1's Avatar
It's that 10% variance according to Mr. Jenetty lol.
Old 01-19-2025, 09:28 AM   #13
m6-lt1
m6-lt1's Avatar
Op, since you said you want a roadcourse car I think you’re significantly better off using the mod money just for seat time. Not sure if you’ve roadcoursed your car yet but if you haven’t get out there and see how you do. I have a bone stock SS 1LE and have passed head cammed SS 1LE’s. Power is not what these cars need to improve, at least not until you become a faster driver.
I think after you take your car out on track you’re going to want wheels and tires, not more power. You will be one of the higher HP cars out there even if you were stock.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
Old 01-19-2025, 12:19 PM   #14
s346k
s346k's Avatar
Drives: like an old lady
use & goals for the car?
budget?
after that is sorted, you can lay out a plan.
edit: if it were mine id upgrade the chassis, brakes and wheels/tires before adding more power.
