Old 12-28-2024, 12:55 PM   #1
donaldp
Drives: 2017 Red Hot ZL1 M6
Roto-Fab Air Intake & CA Smog Check
My 2017 ZL1 will require it's first California Smog Check in two months. Will I need to remove my Roto-Fab air intake and re-install the OEM parts,in order to pass this test?
donaldp is offline   Reply With Quote
Old 12-28-2024, 01:08 PM   #2
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Yes
VR Baron is offline   Reply With Quote
Old 12-28-2024, 06:37 PM   #3
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
YES! and shame on your for ignoring California's strict emissions guidelines!
Old 12-28-2024, 07:32 PM   #4
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
Comedian
IMCWORTH is offline   Reply With Quote
Old 12-30-2024, 12:34 PM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yup unless you have a carb number for it which i think the only air intake for the camaro that is smog legal is the gm one but that was only for the ss models i believe
Old 12-30-2024, 03:22 PM   #6
Rnovrit
Drives: 2018 NFG ZL1-1LE
Unfortunately it will not pass emissions in CA. Just put the stock one back on and go pass. What you do after that is up to you. ;-). Hopefully you don't have a tune as that might be flagged as well. With most ODB-II scanners, you can do a quick emissions systems check to make sure all emissions parameters are ready to go.
Rnovrit is offline   Reply With Quote
Old 12-31-2024, 07:31 PM   #7
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
NOTICE: If you disconnect the battery when changing back to the OEM air intake (per RotoFab install instructions) all of the emissions systems/monitors will reset and will need to be engaged through either a very specific driving routine (which requires a cold start) or just regular driving over the course of a few days. If you try and do the smog right after the battery disconnect, you will fail as the various systems will show "not ready."
ohsmily is offline   Reply With Quote
Old 01-02-2025, 07:11 PM   #8
donaldp
Haha. I'll fart in a bag for a while to offset this.
Old 01-02-2025, 07:12 PM   #9
donaldp
Thank you for this very useful information. I didn't plan on disconnecting the battery, so sounds like I should be okay, correct?
BTW, my battery is eight years old. Trunk mounted batteries last two to three time longer than engine mounted batteries. My dodge Charger battery lasted 12 years in the trunk.
Old 01-02-2025, 07:14 PM   #10
donaldp
No, I do not have a tune, thankfully based on this.
