Old 11-27-2024, 11:12 PM   #1
Chev133
Drives: Chevrolet Camaro zl1
Bow tie emblem removal
Hi,
Dose anyone have any tips on how to remove the bow tie from the trunk lid on a ZL1? I’m replacing it with a black panther Camaro emblem.
Thanks. Anthony.
Chev133 is offline   Reply With Quote
Old 11-27-2024, 11:17 PM   #2
SWFLZL1
Drives: 2022 ZL1
If it is just a stick on emblem, which I believe it is, fishing line works good to “cut” the two sides tape. Then a 3m rubber wheel to remove the rest of the residue, before you put the new one on.
SWFLZL1 is offline   Reply With Quote
Old 11-27-2024, 11:57 PM   #3
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
To add to the above… be careful when lifting the emblem. The corners (just outside of the adhesive tape surface) are extremely sharp and can take a nibble out of the the cheapo Chevy paint.
Old 11-28-2024, 12:04 AM   #4
Chev133
Thanks, I’ll use the fishing line but I’ll also try to soften up the tape with goo remover as well.
Old 11-28-2024, 12:14 AM   #5
I recommend Goo Gone as it's relatively gentle on the paint.
Also, I used a hair dryer (and not a heat gun) to heat the area when removing the old spoiler and rear emblems, it helps the fishing line cut through more easily and cleanly.
Old 11-28-2024, 01:21 PM   #6
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
Doesn't anyone use WD40 for adhesive removal anymore? its the best in my opinion.
and you don't have worry about your paint
IMCWORTH is offline   Reply With Quote
Old 11-29-2024, 08:24 PM   #7
Chev133
Thanks for all the info, just need to wait till the new emblem arrives.
Old 11-30-2024, 08:47 AM   #8
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Yes, I recommend heat, it makes it easier to remove. But be very careful as others have said. I was using a plastic kitchen scraper, should have used something smaller/narrower. Don't let this happen to you.
My Camaro Journal
Old 11-30-2024, 10:43 AM   #9
That SS emblem is upside down, too.
Old 11-30-2024, 03:38 PM   #10
Camfab
Drives: ‘23 ZL1-1LE
Double outch!
Camfab is offline   Reply With Quote
Old 11-30-2024, 06:04 PM   #11
Originally Posted by Camfab View Post
Double outch!
Haha, now that I think of it, the pic itself might be upside down, hard to tell
(Those paint scratches make that less likely, though, probably everyone would start the fishing line cut from the top, and that's where I see the sawing/hacking marks in the photo.)
Old 11-30-2024, 08:31 PM   #12
havelegs
havelegs's Avatar
Drives: 24 LT1 M
I used a rubber wheel to remove emblem tape and it burned through the paint..
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 11-30-2024, 08:43 PM   #13
Chutzpah
Chutzpah's Avatar
I used a my fingers, finger nails and isopropal alcohol. Gave it a quick polish and that was it.
Old 12-01-2024, 05:37 AM   #14
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Don't use a rubber wheel on plastic painted parts (Front/rear bumpers). I have used them several times on my trunk with no issues.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
