Old 11-25-2024, 07:13 AM   #1
Bosse'sBoss
Bosse'sBoss's Avatar
Drives: '16 Camaro SS 6 spd manual transm.
Question How to get quicker reflexes on the Camaro
Hi Guys,
When I replaced my C7 Corvette Z51 for my 6th gen Camaro SS, the only thing that I missed was the quick change lanes feeling in the rear, like quicker reflexes on my Stingray, for some reason my Camaro felt heavier to react in the back. The Camaro its a 9/10 driving feeling from my C7 Stingray. How can I improve this?
'16 Camaro SS
Prior cars:
'14 Corvette C7 Stingray Z51
'14 Camaro ZL1 w/. Recaro seats
'11 Mustang GT 5.0 w. track package
'02 Porsche 911 Carrera
'05 Infiniti G35 coupe sport
Bosse'sBoss is offline   Reply With Quote
Old 11-25-2024, 07:26 AM   #2
SWFLZL1
Drives: 2022 ZL1
Look into the BMR cradle lockout and some of the control/trailing arms. They took the wiggle waggle out of the rear of mine.
SWFLZL1 is online now   Reply With Quote
Old 11-25-2024, 07:49 AM   #3
13brv3
Drives: 2024 1SS Coupe
Does your Camaro have the electronic differential? I had a couple Z-51 C7s and now the 24 1SS (normal diff). I never figured the fancy E-diff did anything noticeable, but now that I don't have it I feel like it was doing a lot more than I gave it credit for. I haven't specifically noticed quick lane change behavior, but I can certainly see that being something the E-diff was assisting with. Any turning while accelerating maneuver feels like it has a lot less traction in the Camaro.
13brv3 is offline   Reply With Quote
Old 11-25-2024, 07:58 AM   #4
Try the same advice that SWFLZL1 gave the original poster. I have this BMR rear cradle lockout kit and it eliminated nearly all the side to side movement of the rubber bushings. Not saying it will be as good as the e-diff, but it will improve side to side and straight line consistency for a relatively low price.
Old 11-25-2024, 08:02 AM   #5
Bosse'sBoss
Both my Z51 and my Camaro didn't came with the mrc suspensions. My C7 had the eLSD but my Camaro SS doesn't have it (only the SS1LE and the ZL1 have it).
'16 Camaro SS
Prior cars:
Old 11-25-2024, 11:10 AM   #6
cdb95z28
cdb95z28's Avatar
Buy a 1SS 1LE with the 370mm front brakes, not the heavier BCD brakes, and install the ZLE's solid rear subframe mounts.
"KEEP THE FAITH"-Fbodfather
Old 11-25-2024, 01:25 PM   #7
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Bigger rear sway bar. I've put the biggest rsb on several front drivers in the past and it really changes the car. The front bites , you can feel the seat bottom pushing up when you turn and the rear rotating.I have 1.3 degrees neg camber on front for more bite.
Gen6cyl is offline   Reply With Quote
Old 11-26-2024, 05:48 PM   #8
Bosse'sBoss
It sounds like the rear Craddle lockout would be a good option.
Do you think that this device would increase the noise and vibration from the road during DD?
'16 Camaro SS
Prior cars:
Old 11-26-2024, 06:05 PM   #9
SWFLZL1
Drives: 2022 ZL1
Originally Posted by Bosse'sBoss View Post
It sounds like the rear Craddle lockout would be a good solution.
Do you think that this device would increase the noise and vibration from the road for DD?
I didn’t notice any extra noise or vibration after doing mine.
Old 11-26-2024, 07:27 PM   #10
Bosse'sBoss
Glad to hear that!
'16 Camaro SS
Prior cars:
Old 11-26-2024, 08:45 PM   #11
No increase in noise or vibration here either, this is a great upgrade with no noticeable drawbacks.
Old 11-27-2024, 07:06 AM   #12
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
I agree with arpad_m response! Just installed BMR suspension mods and it’s been the difference maker so far.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 11-27-2024, 07:27 AM   #13
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Agree with all the BMR suggestions...cradle lockout, to start with, upper control arms, upper/lower trailing arms, front of cradle braces. Works like a charm. I too like a larger rear sway bar, I prefer a looser car than one that pushes on the front.
