Old 11-20-2024, 08:57 PM   #1
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
2023 LT1 seat removal question
Swapping my seat skins from cloth to leather. The rear is finished and ready to get reinstalled. Pulling the passenger front next. Due to lack of garage space currently, I have to pull the car outside to pull the front seats. Once pulled, will I get airbag lights on the dash if I start the car and pull it back into the garage?
Thanks
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 11-21-2024, 04:05 AM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I believe having any airbag/seatbelt unplugged while the battery is connected may cause a airbag light but starting it/accessory mode would more than likely cause an airbag light unfortunately
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-21-2024, 04:11 PM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Most airbag faults will turn the light off on its own once the problem it is seeing is corrected.
Old 11-21-2024, 04:42 PM   #4
7speed
Drives: 21 SS
Thanks
Yeah if front seat is disconnected it will get the srs light, but once reconnected it will go away.
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 11-21-2024, 06:44 PM   #5
LT1Zob
LT1Zob's Avatar
Thank you all. I will have no choice but to pull the seats outside, then trigger the light to pull the car back into the garage. Hopefully no dealer visit necessary as the light will go away on its own. Next winter, I’ll have a lot of space, however, this winter space is at a premium
Old 12-21-2024, 11:42 PM   #6
p47dman
Drives: 2024 Camaro 1SS
Nope, I swapped out cloth for leather also. You will not get an airbag light. Mine is 2024 SS. Although I did not start the car with them out.
p47dman is offline   Reply With Quote
