Old 10-28-2024, 08:01 AM   #1
clg82
Drives: 2020 Camaro ZL1
Wiggle waggle is back....
Hey everyone, finally got around to having the NT 555 RIIs installed on the car and doing some highway pulls I noticed that the "floating wiggle" feeling is back at high speeds. It's hard to explain but anyone with a ZL1 knows what i'm talking about . After installing the BMR Rear Cradle Lockout With the stock zl1 tires installed I didn't have this feeling, should I look at tire pressures with the new tires? If so what are you guys running on the NT555 RIIs on the street? Thanks for any help!
Old 10-28-2024, 09:15 AM   #2
GXP08jrf
Drives: 2016 1LT 'Vert
Thermal Cycles
Do you have enough thermal cycles on the new tires to make a valid assessment? New tires tend to be "greasy" until all of the layers "adhere" to each other and "set".
GXP08jrf is offline   Reply With Quote
Old 10-28-2024, 09:28 AM   #3
cdb95z28
cdb95z28's Avatar
Spot on!
"KEEP THE FAITH"-Fbodfather
Old 10-28-2024, 09:37 AM   #4
clg82
Hmm interesting idea. I drove them 40 miles on the highway, and than about 35 miles back home before my first pull....
Old 10-28-2024, 09:52 AM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I would think that that's enough to get the mold release off of new tires but manuf usually want to say 500 miles. What pressures where you running at that time?
Old 10-28-2024, 10:05 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
put them around 28-30psi for street use.
Old 10-28-2024, 10:10 AM   #7
clg82
I didn't get a chance to check them, but after checking the fronts they were at 42 psi after the install so i'm assuming the rears were at the same, i'll have to take a look.
Old 10-28-2024, 10:11 AM   #8
clg82
will do King, thanks for the suggestion.
Old 10-28-2024, 10:20 AM   #9
GXP08jrf
I don't think that's enough time/cycles. Give it at least a couple more weeks and reassess. I don't think there's a hard-and-fast rule as every manufacturer, compound and construction will be different.
My experience is 2-3 weeks before I feel that a new tire's performance starts to be consistent. This factors in the tire itself and my attention transitioning back to typical driving decisions instead of being critically focused on new tires.
That said the Nittos may like a wider pressure difference track vs street at various temperatures than what you're used to...
Old 10-28-2024, 10:23 AM   #10
cdb95z28
cdb95z28's Avatar
IMO, those tires are sub-par for these cars.
Old 10-28-2024, 10:43 AM   #11
clg82
Huh? Which ones would you suggest then? I've read nothing but good things here on the forums etc for these specific tires.
Old 10-28-2024, 11:00 AM   #12
WhiteMale
agree 42 is much too high I piggy back on the 28-30 and some more break in time. YOu could of course do a couple of burnouts to get there quicker
Old 10-28-2024, 11:55 AM   #13
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Would love to see what tires you recommend for street driven 800+ WHP cars.
Old 10-28-2024, 12:26 PM   #14
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Slicks
Joking a side, I'm curious what the answer is also
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
