Old 10-26-2024, 09:14 AM   #1
Drnick
Drives: 22’ ZL1
Roto fab intake problem?
I installed a roto fab CAI, and I noticed u can’t
Close hood if you have the rain diverter still mounted
Under hood?! Has anyone had same issue? Because
Without the diverter, and if driving in rain, water
Will enter the engine compartment.
Drnick is offline   Reply With Quote
Old 10-26-2024, 11:12 AM   #2
Broooster
Drives: Sharkskin Metallic ZL1
I usually run my car without the rain diverter. If it rains and you're driving, it's not going to matter, the airflow won't allow the rain to get in there. It's when it's parked and rained on, then water supposedly will get onto some electrical connections and "could" cause issues. If you don't park it outside or drive it in the rain often, I wouldn't worry about it too much.
Broooster is offline   Reply With Quote
Old 10-26-2024, 11:38 AM   #3
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Bend the tabs on the rotofab slightly so that the airbox sits lower(where the rubber grommets are) Also, if you don't rotate the intake elbow properly it will also hit the rain diverter.
Otherwise it should not hit the hood or rain diverter.
GM Gen V Calibrator
Old 10-26-2024, 04:06 PM   #4
I've had Roto-Fab on 4 ZL1's and never had this issue.
Is yours the big gulp?
Old 10-27-2024, 07:07 AM   #5
Smokin19
Drives: 19' ZL1 A10, w/pdr
I have not had the diverted on my car for 5 years with a Rotofab big gulp never had any rain or water issue.
Smokin19 is offline   Reply With Quote
Old 10-27-2024, 07:49 AM   #6
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
No issues with mine either the 4 years it’s been installed. Maybe go back and loosen the clamps and try adjusting the intake tube and air box. Good luck!
Old 10-27-2024, 08:25 AM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
Removed my diverter two years ago. I don't drive in the rain, but I spray wash it and never seen any water on the engine. It has a modified BIg Gulp.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-27-2024, 10:43 AM   #8
Drnick
Drives: 22’ ZL1
Well, all seems to be in place, airbox is about “tucked”
As can be, tabs , even if bent , will not make the airbox
Any deeper, it’s the elbow that seems to be causing this
Issue, and I can’t see how I can move elbow any differently
To give me clearance for the diverter,I would only use
Diverter on a trip, if I got caught in a rainstorm.
Old 10-28-2024, 06:15 AM   #9
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Same here, mine fit good with hood closed with only about an 1/16" increased gap on the drivers side where the hood closes along the fender. When Katech did my build and added THPSI Port Injection. This caused the blower to sit slight higher. So they simply notched my rain diverter slightly to allow for the RotoFab Big Gulp intake tube. Now it closes perfectly!
Not sure they are all made to exactly perfect the same. I had a RotoFab BG before my current one that didn't even interfere with the hood closing at all. But I swapped it out because I scratched it where the RFBP logo was and I thought it was an eye soar. So I bought a new one and this one was slightly taller and cased the 1/16" gap. But the hood still closes fine.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 10-28-2024, 06:40 AM   #10
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Mine does not hit the rain diverter...
Old 10-28-2024, 08:32 AM   #11
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Not sure if it's in the area you are referring but when I installed mine 7 yrs ago they supplied a button head bolt to replace the hex head bolt in this location because of a clearance issue. Pic is from install instructions
Name:  rotofab hood bolt.jpg
Old 10-28-2024, 09:24 AM   #12
Yeah, I've never had the Big Gulp which is why I asked, but the OP never answered...
Old 10-28-2024, 09:41 AM   #13
LT4Greg
LT4Greg's Avatar
Attachment 1157310
Yes I was thinking the same thing ZED SLED. I replaced the bolt with the one in the box also.
Old 10-28-2024, 11:19 AM   #14
Drnick
Drives: 22’ ZL1
Not a big gulp
