Old 10-23-2024, 01:50 PM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Oil filter confusion (still)
So, I posted about this in March. The amount of part numbers is ridiculous.
I ordered a PF64 filter on Amazon. The picture of it showed the same part # as listed in the High Performance Manual, 12640445. I just received the filter and this is what I got. Not happy about the Chinese or whatever it is. Could this be a knockoff? The filter looks like the real thing.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 10-23-2024, 01:58 PM   #2
It's most likely the real thing, don't worry about the Korean and Japanese scripts.
The PF64 oil filter has seen a spectacular part number progression over the years, yours is the latest variant: 12640445 -> 12696048 -> 12706595 -> 25206377 -> 25206966
(GM even had two "non-successive" iterations with 19386865 -> 19419226, who knows why they keep changing a $5 part so much.)
Old 10-23-2024, 02:25 PM   #3
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Maybe stop over at Wallyworld and pick one up to compare the two? You can return it or have it for next time? Possibly take yours off the car (if it's same part) compare them if not too messy? That's why I said just pick up a new one. Just an idea.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
Old 10-23-2024, 11:52 PM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
PF64 = PF64, don't worry about the other part number as those change as suppliers change... As long as it is a legit PF64, you should be fine...
Old 10-24-2024, 12:24 AM   #5
discgolf01
Drives: 2018 ZL1 Convertible M6
Its real, Delco went to that packaging design a few years ago. Probably for global cost savings.
Also, this happened a few years ago, but seems like improvements in design:
https://gmserviceinsights.com/new-ac...d-performance/
discgolf01 is offline   Reply With Quote
Old 10-24-2024, 07:18 AM   #6
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
I've used this filter from Amazon the past 3-4 yrs with no issues.
Old 10-24-2024, 07:52 AM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I got a PF64 in the same multilingual packaging last week, I'm sure it's good to go. Though a year or so ago I did return one because I did suspect it might have not been legit but I'm ok with it now.
Old 10-24-2024, 12:08 PM   #8
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Just to throw you a monkey wrench, I like the ACDelco PF63F. More filtering surface area and 22psi internal bypass valve pressure.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 10-24-2024, 08:26 PM   #9
Doesn't the PF63E extend below the bottom of the oil pan or the brace in front of it? I don't recall how much taller that filter is compared to the PF64.
Old 10-24-2024, 10:02 PM   #10
ctrlz
Can't find anyone complaining or comparing fake/counterfeit pf64 filters. That's a relief.
This is a pretty comprehensive comparison looking at the evolution of the pf63 including the change in packaging:
https://youtu.be/ZFOFAXkKnAM?si=vlq49afgmBJNAhxp
Old 10-24-2024, 10:19 PM   #11
2SS Capt
2SS Capt's Avatar
I think you are right and much of the reason the PF64 is shorter... Last thing I want is my oil filter being the "lowest point" and then hear something rub... Those oil filters aren't much thicker than a beer can, wouldn't take much to grind through one quickly leaving one hell of a snail trail in it's wake...
Old 10-25-2024, 01:09 AM   #12
dreksnot
dreksnot's Avatar
Nah. They're about 1" taller, and there's room. Crossbar is lower. Time and weather pending, I plan to do an oil change this weekend and should be able to snap a picture of it installed.
Old 10-25-2024, 08:57 AM   #13
Thank you very much, great info
Old 10-25-2024, 09:43 AM   #14
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I run Delco filters with China writing (they all are that way now) on the daily, But the Camaro gets a K&N HP1017. I like the welded nut on the bottom... makes it easier to get off.
