Old 10-22-2024, 01:21 AM   #1
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Deepest, trueist big V8 sound at idle and under load...
Which exhaust gives you that old school, big V-8 sound? Deep idle but yet deep, throaty acceleration...? Looking at Borla Type S and Borla Atak.... Comments??? Probably doing axel back but open to suggestions, would like to do it myself and not have to do any cutting or welding... Want that old school deep rumble... These cars have 376 ci engines, they should be able to do that...
Old 10-22-2024, 07:52 AM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
If pricepoint is not a thing for you, Borla. My AWE (touring) system on my LT1 got lot's of compliments. Corsa is popular but sounds to raw and aggressive for my taste. I like the MBRP axle back I have on my ZL1, basically a muffler delete and does not drone.
Old 10-22-2024, 08:15 AM   #3
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
Borla ATAK. Been very happy with mine. Sounds like a V8 muscle car should. It's really only louder than the stock NPP under full throttle. Just cruising it sounds about as loud as oem, and zero drone.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 10-22-2024, 02:07 PM   #4
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
My lgx sounds great to me. Lt1 guys rolling in lgx section.lol
Gen6cyl is offline   Reply With Quote
Old 10-22-2024, 05:54 PM   #5
2SS Capt
2SS Capt's Avatar
Oppsss... Didn't even notice that...
Old 10-22-2024, 06:17 PM   #6
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
check out afe power catback its awesome and works with npp ive had mine almost 9 years no issues
Old 10-23-2024, 07:18 PM   #7
GreyGhost702
Drives: 2019 Camaro 1SS1LE
I'm a fan of Magnaflow & Stainless Works product. I've used Magnaflow on just about every sports car I've owned, they always had a muffler that was right for the combo. I went Stainless Works Redline on this build and I love the sound, but I really wish I had gone Legend series as it is the deeper toned of their product offerings. It'll be better once I get the HOHF cats on, but right now the car is punishingly loud with the valves open. Closed it's nice and tame.
Here's mine valves open, granted not quite stock.
https://youtu.be/FAa0Y4JJcTc?si=FEpbGsfhwh61WEz9
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 10-23-2024, 11:50 PM   #8
2SS Capt
2SS Capt's Avatar
I guess I should have said I'm pretty much looking for an easy axle back... But want something deep at idle and thought acceleration more like an old school muscle car...
(I asked the mods to move this to the V-8 section a couple days ago... crickets...)
Old 10-24-2024, 11:14 AM   #9
GreyGhost702
It was just a suggestion for tone, not saying you should go all-out. Just changing the muffler is only going to adjust the tone of the exhaust. If you check out Stainless Works, they have a well put together video sample of the Legend and Redline series on an otherwise OE Camaro test car. I'd press you to replay the stock vs axleback areas of the video repeatedly so you can really compare the difference between the OE muffler vs Aftermarket, as the distinction between the OEM muffler in Aftermarket Mufflers by themselves are just adjustments in tone and usually very minor. If you remove the secondary cats, the entire exhaust note and volume is noticeably different. Arguably, your best bang for your bucks is going to be keeping the OE muffler and removing the secondary cats. Everything from volume, tone, even the burbles/crackles is going to sound 2x better. If you live in Cali, I wouldn't suggest it, most smog shops can count cats, even if the modification doesn't throw a code (which it doesn't).
Changing out the muffler by itself, the only way to get a deep tone is with a chambered muffler or case style muffler. The straight through mufflers play on essentially a straight pipe tone, and how the muffler is packed and baffle design which just reduces specific frequencies based on the size of the holes. While you may get a nice thump at idle, most straight through designs are raspy under load. I've always thought of it as:
Case/Chamber style = least raspy but not the loudest (tuned and deeper tones)
Straight-through/Tube style = most raspy but the loudest (more natural straight-pipe tones)
Most people are unsatisfied with the OE exhaust simply because they just can't hear it well enough, it's not at an enjoyable volume. Sure, valves open, rev'd out, you hear it a little bit. From the Drivers perspective, the car is too well insulated and exhaust exit diverts all of the best frequency away from the car, so you really aren't hearing the OE exhaust as gloriously as the guy next to or behind you. Drop the secondary cats, you may find that muscle car tone you're looking for without dropping $1500-$2500 on mufflers.
All this talk of exhaust pulses is making me fiend. Need to get the car out now.
Old 10-24-2024, 02:54 PM   #10
Gen6cyl
I have x pipe in place of the resonator and mbpr axel back for 1.5 years. Could not be happier with it added so much enjoyment.
Old 10-24-2024, 10:37 PM   #11
2SS Capt
2SS Capt's Avatar
Unfortunately, I do live in CA (for about the next 2 years, my car is a 2020 so I am going to run right up to my "vehicle inspection", how easy is it to remove the secondary cats?
Old 10-25-2024, 09:50 AM   #12
GreyGhost702
As easy as it is to rent a sawzall and rent a welder to weld in a pair of straight pieces in place.
I had a local muffler shop do mine because for the price, I'd save my back. It was stupid cheap. Easy enough for a DIY'er as long as you have some experience melting metal. Just want to make sure you leave as much pipe on the Primary cat side as possible and cut as close to the secondary as you can. You can't have even a small exhaust leak here, or it will throw a code. Once removed, get your jacks and jack stands to hold the rear exhaust in place and get a good fitment on your straight pieces. One or the other side will be not-so-straight due to the inlet/outlet of the secondary cats not being a perfect alignment in the first place. That's okay. Get a few good solid tacks in place, and then you'll want to drop the primary cats off of the exhaust manifolds. PB blaster or deep creep or Kroil is your friend here, let it break the metal loose. Once unbolted, you'll be able to weld completely around your pup pieces no sweat. Spray paint the welds after cooled for anti-corrosion, and bolt the primaries back up. Done. No tune required and the car will now sound like we wish it had come from the factory.
Old 10-27-2024, 02:23 PM   #13
retmil
Drives: 2022 Wild Cherry SS
I have the SW 3" cat back Legend system with NPP setup on my 22SS and really like the deeper tone. Also eliminated some of the crackles and pops on decel. Has been on my car for two years with zero issues.
retmil is offline   Reply With Quote
Old 10-27-2024, 02:27 PM   #14
Keko
Keko's Avatar
Drives: 2023 ZLE M6
I went with the Borla S-Type over the ATAK since it's more of a classic muscle sound. ATAK has some of that modern "raspy" sound in it, which I'm not a huge fan of. It still sounds good, but S-Type was the easy choice for me.
The S-Type sounds absolutely fantastic, and it's not quite as loud as the ATAK, which is kind of nice. It also eliminates a lot of the raspy sections from the stock exhaust, especially around 2-4k RPM under medium load. I really disliked that range on the stock exhaust.
Here's a short clip of my S-Type.
https://www.youtube.com/shorts/rMuqC...?feature=share
2023 ZLE M6
Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid
2024 Polestar 2 AWD
Keko is offline   Reply With Quote
