Old 10-02-2024, 04:56 PM   #1
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
How-To: Install BMR BK063 Rear Cradle Bushing Lockout Kit
Installing the BMR BK063 Rear Cradle Bushing Lockout Kit on the ZL1 Camaro:
Overall, not to bad of an install! The bullets you need to hammer into place is the only headache, lol.
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 10-03-2024, 08:54 AM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Agreed, the bullets are a real PITA though I had the same with my Mustang PP, used the same thing from Steeda. Makes a tremendous difference in the rear end though.
I added the (non adjustable) Upper control arm, and upper/lower trailing arms recently, those were def worth it.
Old 10-03-2024, 10:50 AM   #3
willzilla
D3RPZILLA
willzilla's Avatar
Awesome, good to hear! I've added non adjustable upper and lower trailing arms and upper control arms to the passenger side. Taking my time with the driver's side as I'm doing a video on everything, lol. After those are all done I'm adding the front and rear sways bar and end links. Looks awesome so if it performs as awesome as it looks I'll be happy, haha.
I also had added the rear cradle front chassis braces which complements the lockout kit nicely.
Old 11-14-2024, 01:34 AM   #4
cdrptrks
cdrptrks's Avatar
Yep, I ended up using a floor jack with a piece of 2x4 to push the metal bullet things in because the exhaust was in the way of the hammer.
Also, the 4 long bolts are supposed to be replaced with new ones according to the service manual.
Old 11-28-2024, 08:27 PM   #5
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
That's the samething I did was use a floor jack that comes in the cars that's small for the side of the road. made the work a breeze. Overall straight forward install
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
bk063, bmr, cradle lockout, suspension, zl1
