![]() Drives: 2024 2SS 1LE Join Date: Nov 2023
JL audio stealthbox
I installed a JL audio stealthbox and wanted the installation to be as clean as possible. First I bought another side panel so I wouldn’t cut up my original for the installation. I tied into the amp with a T-harness and an ANC bypass cable from T-harness.com. I hooked the harness up to a Wavetech link DQ. I used a 1/4” hardboard to make a mounting plate for the amp on the opposite side of the speaker. The amp is a JL XD600/1 v2. There were some holes in the body that I utilized for mounting the amp board. I used some rubber expansion nuts that I shaved down to fit the body holes which when tightened expand and will not come out. This also gave me some vibration dampening when the amp is mounted. Overall I am very happy with the installation and with the trunk open you can only see the speaker.
Finished installation.
![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
Nice job - that looks awesome! I wish they would have made one for the convertibles. I would love to have an off the shepf option like that.
-Geoff
Thanks for posting. I'm going to have to take a closer look at this, that looks so clean. I would love to move my amp & sub out of the trunk area.
Any pics of the area where the sub is installed, with the side panel removed?
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
![]() ![]() Drives: 2016 M6 2.0T Join Date: Nov 2016
Dude, WTF. That is awesome. I need this in my life.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
![]() Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
That makes two of us!
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
#7 |
![]() Drives: 2023 Chevy Camaro Join Date: Aug 2023
very nice! bet that thumps!
#8 |
I just checked behind the side panel on my car. Other than using a JL Audio Stealth Box, I don't think much else will fit in there.
#9 |
#10 | |
But I meant for a subwoofer behind the driver's side panel.
#11 |
![]() Drives: 17 camaro ss Join Date: Mar 2018
How much did you pay for that box? I can only find them for around $1500.00 and I'm sorry, looks great but that's definitely not worth $1500.
#12 | |
![]() Drives: 2000 WS6 Join Date: Dec 2014
I shopped around a little. You can't buy the enclosure unloaded, without a cone, but there is (or at least there was) a version from JL for around $1200 with a cheaper cone in it. The cheaper JL Audio SB-GM-CAM6G/12TW3 94633 vs SB-GM-CAM6G/12W6v3 94632 |
#13 | |
-Geoff
#14 |
Electrical Engineer
There is a lot of room on the driver's side.
![]() I like the StealthBox, and it's worth the price, but I'm wanting to put my amps in that recess instead. I haven't finalized the decision yet, but this is the fitment: ![]() Acoustical treatments will go a long way in making that sub sound a lot better. The hollow cavities in this car are an awful platform for a sound system. I have all cavities filled with sound absorption, and metal surfaces treated with a combination of CLD then CCF over top. ![]() ![]() ![]() ![]()
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
