![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Recently completed some testing Goliath pump Q and A
Been really busy not much time to post, I found a few minutes to share this
We are really pleased with the results of our testing especially knowing it has more head room than we needed for this build. 875 RWHP on E 80s The video explains a lot please feel free to ask questions. https://www.facebook.com/jannettyrac...65267441902157 Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
Sorry if it was covered in the video, but what lowside was on the car?
So with a lowside, Goliath hpfp, and +30 injectors it made 875rwhp on 15.6 pounds, and handled e80. Pretty impressive! You said injectors were close, but I didn't quite catch the EOI, thought I heard 150*? |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
32% or 38% fuel lobe?
GM Gen V Calibrator
#4 | |
Never talked about EOI, I did talk about Injection pump duration though Still under 90 degrees.
From the calibration I see it was 38 which was in the car when the customer bought it.
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
1. Ted... How the hell do you look younger in this video, than the videos from a few years ago? How is that possible???
2. Great numbers on this build! 3. Sounds like you went from 815 to 875 from the 30+ & Goliath? If so... How much of that number do you attribute to the Golaith considering the car already had a 38% Cam Lobe? Keep up the good work!
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#7 | |
![]() The fuel system allowed us to go to a larger lower pulley which is responsible for the extra power. Without fuel you can't make power or support more boost. I don't attribute any of the power gains from the fuel system parts. The parts support the higher boost and more E. I hope that clears things up. Ted.
#8 |
#9 |
![]() Drives: 2024 ZL1 M6 Join Date: Sep 2018
What fuel pressure did you target? Since the Goliath debut I’ve been tempted to try the XDi’s as they seem to hold more pressure now that we have a hpfp that can supply it. Have FIC/big bore combo now.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp Kooks 2 inch LT's, Stainless Works Legend NPP THP Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
#10 | |
The Goliath is capable of 350 bar (5076 psi) and handling 8 mm of stroke so when the injectors get better able to handle more pressure we can move higher and gain more flow. I believe 8mm of stroke is considered a 40% over the LT1 5.7mm lobe. Ted.
#11 | |
#12 |
I do not know we can get to 3200 psi with any of the % over injectors I have been as high as 2800 with XDI 65% overs.
#13 |
The older XDI +30's will do 2900 psi with no issue. I believe the newer XDI +30 and +50 are now rated for 3200psi max. The XDI +65's(discontinued) are rated to 2600psi. Never tried higher because the LPE HPFP couldn't keep up. The newer +70's are rated for 2800psi. XDI basically raised the ceiling 2-300psi for all of their injector offerings.
FIC +30 are hit and miss if you try to run them at 2900psi, they seem to have less issue around 2600psi or lower. None of this mattered much in the past with the LPE BB HPFP because it doesn't seem to like running much more than 25-2600psi. Now that the Goliath pump is available, I would get the XDI and run LT4 pressure(2900psi) to start.
#14 | |
