![]() Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
Anyway reccomendations on how to keep cool?
I have a cammed A10 SS and whenever Im in stop and go traffic the car gets super hot. Floorboard and Kneepad areas get hot to the touch and the car severely loses performance and all the Temps read normal levels.
This ONLY happens in stop and go traffic where the pauses are just short enough so I have to stay in drive but I cant go over 5 mph at a time when its time to move. I live in CO so the DA is awful but was just wondering if there are any decent cooling mods anyone could recommend. Car runs better after a long trip with multiple long pulls at full throttle and idling in park for 20+ min then it does in stop and go traffic for 10 minutes on a cool night. anyone know why? It runs fine after I let it cool for a bit but its crazy how hot it gets in traffic. |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
Unfortunately the tunnel in these cars is super tight. Between radiant engine heat and heat off the transmission mostly, it's hard to get away from when you aren't moving. You could do thermal matting in the tranny tunnel, but that's quite the undertaking. It's essentially dyno-mat. You could alternatively insulate it from the interior, but I think it's better done in the tunnel.
Beyond that, set the A/C on floor and let it blow. If you could bring all your mechanical temps down or evacuate that heat quickly while not moving, GM and other manufacturers would love to know how you do it.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
My suggestion would also be to direct the A/C to the floor, not much more you can do without significant effort and expense. Interestingly, I never noticed anything like this on my non-stock SS...
#4 | |
Moderator
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
the console in my c4 got so hot you couldn't touch it. it was ridiculous. 100% stock at the time. i'm hoping ethanol and an aluminum engine mitigates some of that nonsense. if its still really hot i'll do lizard skin or some kind of heat barrier. not much room in the tunnel above that t56 magnum tho.
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
A few questions...
1. Do you have HP Tuners? 2. What coolant / oil temps are you seeing during cruising vs after a long stop? 3. What are your fan settings? I can share mine if you like... it is an easy change, and helps alot!
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#7 | |
#8 |
Also, do you have headers?
This sounds to me like your timing is retarded and you are burning fuel (or dumping too much heat) in the exhaust. Do you have one of those IR thermometers to get some temp readings? They are cheap on amazon: https://www.amazon.com/Infrared-Ther...ca7fbcb4f299c0 |
#9 | |
#10 |
#11 |
Yeah I may have my tuner take a look. But like I said, all these symptoms ONLY happen after being in stop and go traffic in particular. Its fine after a day driven hard or idling in the sun but stop and go traffic really does a number on it.
#12 |
![]() Drives: Chevy Camaro Join Date: Sep 2022
Couple things to consider and what I've done to help my personal turbo setup.
I have a 160 thermostat and fans turning on early, I'd have to look at tune for specifics but my engine coolant never gets over 185 really. My biggest heat issues are sitting idling for awhile and the whole thing heat soaks, pulls in hot air and takes a little bit of steady driving to cool the oil temp and intercooler down. This could definitely be tune related. The ecm uses maf and speed density info at different times to appropriately fuel the car. There are also idle specific tables. If the torque model is off in the transition off idle and up into part throttle cruising, it could move timing around alot trying to hit it's target. If that timing is pretty low and you do it over and over again, like stop and go traffic it could naturally build up a lot of heat. This kind of seems likely to me because you say it's fine just idling. The separate idle tables are keeping idle timing up.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels. 1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake |
#13 | |
Yeah its super jumpy at idle, mainly because I'm still running the stock converter wondering if upgrading that would fix the issue. |
#14 | |
As jlaudio mentions, idle is going to be an open loop mode, and the car will use tables to match fuel and spark timing to density (from MAF data) and speed (engine rpm). Coolant temp is also a factor. You need to know what your A/F is at idle. Sounds like it might be overly rich. This needs to be tuned to get it right, particularly with your mods. |
