Old 09-08-2024, 08:31 PM   #1
german tarquini
Drives: audi s3 2008 bmw 135 2010
forged engine spark advance tips
Hello .. on lt1 supercharger centri engine 10 psi at 6.5 rpm forged low compression 10.2 lt4 fuel system plus jms ..how many degrees of spark .. stock internal 13 14 degrees on 93 octane
german tarquini is offline   Reply With Quote
Old 09-08-2024, 08:41 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
13-14 degrees on 93 octane is probably about all you’ll get. You can try an extra degree at a time and see if the motor is happy (and no knock retard) but don’t expect you’d get too much more than 14.
Old 09-08-2024, 08:56 PM   #3
german tarquini
10.2 compression also 13 or 14?
Old 09-08-2024, 09:59 PM   #4
Joshinator99
Moderator
I’d start there like I mentioned above. If you’re running clean with no knock, then add a degree or two and see how it responds. Might be able to get a bit more but you’re not running 20 degrees lol
Old 09-08-2024, 11:58 PM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
That compression should allow for 17 degrees at that boost level. You are just a tick above stock LT4 compression and I have seen them tolerate 17-20 degrees depending on the quality of fuel.
Old 09-09-2024, 04:29 AM   #6
german tarquini
Thanks..I'll try with 16 from 5.6 rpm and we'll see.. test 15 degrees and 0 kr
Old 09-09-2024, 04:50 AM   #7
german tarquini
dragy data 0 gain 100 200 km .. in 15 degrees
Old 09-11-2024, 01:39 PM   #8
RsSebasC6
Drives: EvoVIII ,Wrx Sti, S2000, RSClio
Hi guys! I am Sebastian from RSTronic in Argentina, helping German. He is running built engine, forged pistons and rods, compression 10,2. ECS SC with 10psi at 6500rpm. We need some help on tuning the new TCM that we bought from HPTuners. Who do you reccomend for a remote tuning please. We are also ready to tune the ECU for flex fuel.
RsSebasC6 is offline   Reply With Quote
Old 09-11-2024, 07:56 PM   #9
Ted Jannetty (jannettyracing.com), +1 (203) 753-7223
Old 09-12-2024, 09:17 AM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
Thank you for the referral.
I hope all is well.
www.jannettyracing.com
email tedj@jannettyracing.com
