Old 08-12-2024, 01:39 PM   #1
Whoomba
What do you guys use to dry glass?
I use to use newspaper. Worked great. Who has newspaper anymore? I had a chamois but it wore out. Microfiber streak. Got a better suggestion?
Old 08-12-2024, 01:53 PM   #2
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
+1 I thought of ordering the Sunday paper just to have some on hand.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 08-12-2024, 02:46 PM   #3
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
I've actually had the best luck using microfiber. The Rag Co. microfiber towels on Amazon are good. If you need Walmart, get the more expensive ones. Weave towels are supposed to be the best for glass, but I don't think they're any better than a good microfiber. Stoner glass cleaner is widely available including Walmart and will probably give the best results (many detailers use it - it performs as well as many products that are much more expensive). You might have to wipe several times to get rid of streaks, or use one towel with cleaner, and then a clean dry towel.
My Camaro Journal
Old 08-12-2024, 03:30 PM   #4
Coded4SS
Drives: 23 Zl1
You need to use a waffle weave towel with glass cleaner. Waffle weave used only on glass (and washed beforehand with microfiber wash) will do it, no streaks, clear windshield, no lint
The towel:
https://amzn.to/46LfiQe
Microfiber Wash:
https://amzn.to/3yD0Qxa
Glass Cleaner:
https://amzn.to/3SL12Bc
Coded4SS is offline   Reply With Quote
Old 08-12-2024, 04:56 PM   #5
grampa_ss
grampa_ss's Avatar
I 2nd the waffle weave towel.
Old 08-13-2024, 09:23 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Waffle weave works great on glass... after a pooling rinse & leaf-blower dry.
Old 08-18-2024, 05:37 PM   #7
OneLapWonder
Drives: 2008 Audi RS4
I use 100% cotton cloth cut from bed sheets. You still have to wipe when the glass is cool to avoid streaks, but that’s a universal problem, not dependent on the type of wiping material.
2012 Lexus CT200h Premium Navi
2008 Audi RS4
2004 Audi S4
2018 Chebby Camaro ZLE HMB
OneLapWonder is offline   Reply With Quote
Old 05-20-2025, 10:22 AM   #8
p47dman
Drives: 2024 Camaro 1SS
It is all in the order that you clean. First, spray and let soak, wipe off bugs and dirt, spray again and wipe with clean towel, now use dry towel before streaks appear. Gotta be quick in hot weather or direct sun. And I clean this windshield many times a day.
p47dman is online now   Reply With Quote
Old 05-20-2025, 10:24 AM   #9
p47dman
PS, I just use plain , spendy, paper towels.
Old 05-20-2025, 01:46 PM   #10
I've tried almost everything under the sun, the only thing that kind of works is brand new waffle weave towels. Even those aren't perfect, my glass is never as clean as the paint. Somewhat surprisingly, the cheapest Sprayway cleaner from Walmart has worked the best for me, all the expensive glass cleaners I tried left something behind, streaks or dirty spots. There is one more I haven't yet tried (Amsoil).
Haven't given up yet, though, one day I'll find the perfect product and towel. Or, as some might be tempted to taunt, I'll finally learn how to clean glass
Old 05-20-2025, 02:36 PM   #11
bbraswell918
bbraswell918's Avatar
I use The Rag Company Glass cleaning towels with Invisible Glass. Zero complaints and it works very well on the glass.
2016 Camaro 2SS A8 || SE 2 inch Longtube Headers | SE Offroad X-Pipe | Corsa Extremes | DSX Flex Fuel Kit | MSD Atomic AirForce Intake Manifold | NW 103mm Throttle Body | Roto-Fab Cold Air Intake | Oil Catch Can | e85 Dyno Tune
bbraswell918 is offline   Reply With Quote
Old 05-20-2025, 06:29 PM   #12
p47dman
Was not inferring anything!
Old 05-20-2025, 08:35 PM   #13
DamonZ28
DamonZ28's Avatar
I have the best luck with The Rag Company Edgeless 365 Microfiber Towels. I've tried the waffle weave towels, good quality towels, but I keep coming back to these.
My Camaro Journal
Old 05-21-2025, 10:20 AM   #14
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Are you using the 280 or 350 gsm ones?
Like Arpad, my waffle weave glass towel seems to do the trick only when new - interested in trying these out as I am an Invisible Glass fan as well!
