Old 08-10-2024, 07:18 PM   #1
Waleedriazz
Drives: 2018 1LT Camaro 2.0 I-4
Fromt Bumper Solutions, Anyone?
Hello,
My front bumper clip is broken, which makes it pop out slightly at times. I can't replace the bumper or take it off (as the other clip was glued).
Any recommendations on how i can fix it?
Thanks
Waleedriazz is offline   Reply With Quote
Old 08-10-2024, 08:09 PM   #2
GreyGhost702
Drives: 2019 Camaro 1SS1LE
If you're not doing some kind of conversion kit like SS to ZL1, you can get an OE style bumper just about anywhere. Summit Racing, American Muscle, some OE body parts.com places. Work with a local body shop for a paint estimate, don't cheap out on the flex additive.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 08-11-2024, 11:26 AM   #3
PostalLDMC
PostalLDMC's Avatar
Drives: 2022 2LT RS Convertible
If you want a cheap out and can't replace the bumper. Try super glueing it on just clamp the corner up till it sets up. You have nothing to lose but time.
PostalLDMC is offline   Reply With Quote
Old 08-11-2024, 03:43 PM   #4
Waleedriazz
I do want to cheap out because eventually I will look for a conversion kit, so thank you! Do you have any recommendations on what super glue is going to hold it? I used one but it did not work
Old 08-11-2024, 04:16 PM   #5
Callaway SC630
Callaway SC630's Avatar
Drives: 2020 Callaway Camaro SC630
Use a two-part epoxy. Gorilla Glue and others make 1000 to 2000 pound quick-dry versions.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue
Callaway SC630 is offline   Reply With Quote
Old 08-12-2024, 12:24 PM   #6
oldguy0130
oldguy0130's Avatar
Drives: 2021 2SS red-line Camaro
I would go to an autobody paint supply store. They have solutions for those problems.
oldguy0130 is offline   Reply With Quote
Old 08-15-2024, 10:46 PM   #7
Waleedriazz
10 bucks spent. Looking good so far. Will keep you all posted
Old 08-15-2024, 11:16 PM   #8
JoeCamaro444
JoeCamaro444's Avatar
Drives: 2018 2SS M6 Hot Wheels Camaro
Hopefully this does the trick for a long time.
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars:
2017 1SS Nightfall Gray Metallic w/A8 and NPP
1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps.
JoeCamaro444 is offline   Reply With Quote
