TSP Timing Chain Guide Vs LME
I've been looking at the LME timing chain guide but its $240 bucks and that seems like a stretch for upgrading a $30 tensioner to a guide.
Has anyone seen this Texas Speed one or have any general thoughts on it? Seems like a good compromise for only $99 and gets you away from a tensioner. TSP Timing Guide
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB Pray ported MSD IM Rotofab CAI BTR 225 CAM PRC 312 CC Ported Heads Katech Oil Pump DSX Flex Fuel E-85 kit QTP exhaust cutouts Full JLAudio Stereo Build w/ 13-W6 |
#2 | |
Moderator
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
They work the same. LME uses a 1 piece billet aluminum design. Can't tell what the TSP guide is made of but it's not a 1 piece design, it has composite (plastic) pads on the guide ends. This makes it at least a 3 piece design. The pads will wear much faster than the billet aluminum. 60k miles, 120k miles, who knows. I'd be upset if the black portion wasn't at least steel though. It's definitely the budget piece between the two. I've lost $150 (way more) in a slot machine before, so the LME still felt like a good deal to me and that's what I'm running. I think the updated OEM tensioner would've been just fine, but I like billet stuff.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
Have you actually seen the LME chain guide? It sounds like either they changed the way its made or you haven't actually seen one. That looks like it has composite (plastic) pads on the guide ends. I think I'll save some money and check out the TSP one. Maybe LME will end up lowering their price since they aren't the only option in town anymore.
#5 | |
Moderator
#6 | |
I stand corrected. I guess I didn’t really notice the pads with all the hypnotic billet bling. If the TSP one is steel, that would be the price difference. And yes, I have actually installed one and fondled it, too. Just didn’t recall the piece correctly. A thousand pardons for my error, sir.
#7 |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
Support the innovator and not the copier. I'm all for competition in the market but when you knock off a product basically 1 for 1 I can't get behind that. We will only use LME chain guides in our builds that require one.
#8 |
While I don't like companies ripping other companies designs off. I don't think much of this is original from LME either. They just took the original LS2 dogbone and gave it 3 bolts to mount to the current engine. Not sure what else TSP would need to do to make it unique to them. To each their own and I can respect that.
#9 | |
#10 | |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
What are the indicators where a chain guide would be required over the OE tensioner? BTW, I have the LME guide in my LT4.
