Old 07-24-2024, 09:39 PM   #1
Tboyk
Drives: Black 2023 LT1 A10
23 A10 transmission Failure 20k miles
Whining noise at low speeds after car warms up but can also be heard with car in park and slightly reving. Sounds like a pulley but dealership says needs new transmission. Does this sound possible?
Tboyk is offline   Reply With Quote
Old 07-24-2024, 10:12 PM   #2
KC64
Gray Ghost
KC64's Avatar
Drives: 24 Camaro 2SS Loaded
Anything is possible. Toyota is fighting with their V6 motor because it seems to be blowing up in their 22, 23, and 24 so a trans here and there is possible.
Seems like it should be under warranty and if the dealer says you need a new trans have them replace it or do what ever they need to do?
KC64 is offline   Reply With Quote
Old 07-25-2024, 02:18 AM   #3
Kamero6
Drives: 6th Gen LT1
It Could be the oil pump intermediate bearing. The bearing gets loose and the gear moves forward or backwards and starts to whine.
Kamero6 is offline   Reply With Quote
Old 07-25-2024, 04:43 AM   #4
Tboyk
Warranty will cover it.
Old 07-25-2024, 02:37 PM   #5
gen6_1ss
gen6_1ss's Avatar
Drives: 2023 Sharkskin Metallic 1LE
I had the same issue a while back, there is a thread in the transmissions section under A10 subtle whine with more info, I am copying what I wrote in my post with the outcome. Go check out the thread.
"So, I just picked the car up from the dealership yesterday after it being there for a month. They were able to reference a service bulletin #22-NA-232 which references the 10-speed oil pump drive gear. They ended up replacing the idler gear, damaged torque converter, transmission case front cover, input shaft support bolts, transmission fluid pump, and the transmission fluid filter. The car only hit 10k miles not long ago, and my service writer told me I was lucky to have it repaired now, could have cost GM a whole new transmission. This was all covered under warranty, but it would have been quite costly if it wasn't.
So, my advice is if you hear a whine noise coming from your car, take it in and have them look up this bulletin."
gen6_1ss is offline   Reply With Quote
Old 07-25-2024, 04:27 PM   #6
Tboyk
That would make sense. Explains why the whining can be heard at idle.
Old 07-25-2024, 10:15 PM   #7
Kamero6
Drives: 6th Gen LT1
I could't find much, but is it this noise?
Old 07-26-2024, 08:58 AM   #8
Tboyk
Yes
