![]() Drives: camaro ss Join Date: Nov 2023
honeywell hobbs pressure switch adjustment
hello so i have a hobbs switch thats suppose to kick on and activate my secondary pump between 4-6 psi it’s adjustable. fro factory they are preset at 5 psi i’m trying to turn it down to 4psi i saw a screw at the top that i think might be what controls it but im not sure does anyone here have any experience w these
Moderator
Usually turning the adjustment screw out (counterclockwise) lowers the activation pressure, while turning it in (clockwise) raises the activation pressure.
any idea how far? i was messing with it and it seemed like i could pull it all the way out if i wanted. i ended up leaving it at the point it the point where a few threads show
Moderator
Yeah I wouldn’t go crazy. Maybe one turn out and give it a try.
didn’t make a difference. making thinking if i should try going in?
Moderator
Going in should raise it since it’s typically a set screw pushing against a spring mechanism.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Josh is Correct turning it in increases flow. Funny last night I was just talking to my tuner about the meth controller which uses a Hobbs switch.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
