Old 06-11-2024, 07:09 PM   #1
Rkspeed
Drives: SS 1LE
Torque Question
I have a 2022 Camaro SS 1LE,
Does anyone know the torque settings for the tpms wheel sensors?
Rkspeed is offline   Reply With Quote
Old 06-11-2024, 10:26 PM   #2
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Wow. Never even considered torque values for tpms sensors. Rubber ones get shoved in, screw ones get tightened down. You may be overthinking this one, but I'm in for other comments. Maybe I'll learn something
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 06-11-2024, 10:33 PM   #3
Rkspeed
Drives: SS 1LE
Torque
This car is tracked.
When you track a car torque matters to wheels anything around the wheel... calipers, wheels, suspension parts and tpms sensors.
Old 06-12-2024, 12:31 AM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
71 in/lb...
https://31inc.com/wp-content/uploads...tion-Chart.pdf
Old 06-15-2024, 09:45 AM   #5
s346k
s346k's Avatar
Drives: like an old lady
be sure you get the torque value for the valve stem cap, as well. however, im sure you can find another set that say "camaro" like the ones you already have.
Old 06-15-2024, 11:55 AM   #6
Slip3Kid
Slip3Kid's Avatar
Drives: 2023 Camaro 2SS
Mine say SS IN RED!!!
23 2SS M6
1/30 1100
3/23 2000
3/31 3000
4/04 3400 TPW 4/17
4/19 3800
4/20 4300
4/22 5000
4/24 6000
Slip3Kid is offline   Reply With Quote
Old 06-15-2024, 03:09 PM   #7
Caerus
Caerus's Avatar
Drives: 2023 Camaro ZL1
I know your comment was mostly "tongue-in-cheek"
But valve stem caps should not be used on the race track so no torque required. First they end up being foreign objects on the track surface causing issues. After a track run session they hinder quick tire pressure readings.
Also, applying the proper torque specification of a TPMS sensor to a wheel rim is a real thing and should be adhered to. From my experience they run between 35-80 in-lbs depending on sensor type. 2SS Capt provided 71 in-lbs which sounds good.
2023 Camaro ZL1 6MT Summit White
Caerus is offline   Reply With Quote
