Old 06-09-2024, 10:17 PM   #1
race24x
Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS
18 ZL1 Anyone do these mods have results
Hi there I am looking to do some mods to my ZL1 and wondering if anyone has done these and what their results were.
1. Big Gulp
2. Kong Xport
3. 2.3 pulley
4. 103MM TB
5. Custom Tune
Stock manifolds stock cats but some Cat back that is pretty loud
1980 Z28 AWSM-Z
1993 Z28 AWSM-Z
2014 2SS AWSM-SS
2018 ZL1 AWSM-Z
race24x is offline   Reply With Quote
Old 06-09-2024, 11:53 PM   #2
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
1. Big Gulp
2. Kong Xport
3. 2.3 pulley
4. 103MM TB
5. Custom Tune
Skip the 2.3 pulley, it will just make you heat soak more. Instead, get a FlexFuel sensor and run a 30-40% mixture. Headers will open it up a lot more if you add that to the list. Check my signature, I have similar mods and made 731WHP on a stock size pulley.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 06-10-2024, 06:12 AM   #3
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Research a bit more before doing those exact mods! I did the Kong X-port and a 2.3" Griptec. I quickly found out after doing so, I didn't have enough fuel system. I was running E60 prior to those mods and my car felt crazy strong. Then, after the X-Port and the 2.3" pulley, my car felt good low end, but then around 5300rpm. I was dropping fuel pressure up to 400psi to 600psi from command. The car feel flat, it was out of fuel top end. So, we had to pull the E mix back, way back. At E15 it was still running out of fuel around 5900rpm and the car made 649rwhp / 534rwtq on the Dyno. I then sent my car to Katech and they upgraded the fuel system, added Port Injection and added a 9.45" lower and a few other misc. items. It's now making 784rwhp / 627rwtq on the Dyno. As in Rapid_blue_zl1_22 signature, he shows he also added the Katech Duel Fuel Pump upgrade. Also, don't be surprised if you do X-port and see a lower than expected torque number. It's just the nature of the X-port. You might want to consider Kong's regular porting option and as mentioned skip the 2.3" upper. Add a DSX Flex Fuel sensor, DSX aux pump or JMS Voltage Booster and run E60 and love how your car drives !!!
Here is my build threat if you can lean something - Great!
https://www.camaro6.com/forums/showthread.php?t=611982
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 06-10-2024, 08:01 AM   #4
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
1. Big Gulp
2. Kong Xport
3. 2.3 pulley
4. 103MM TB
5. Custom Tune
Common build and I tune a lot of these. Just the above mods will be in the 660ish rwhp range give or take depending on the dyno and how much timing it will take.
Without headers, you will have a hard time keeping any timing in it so you will want Flex Fuel if you have any pumps near you. You can run E30 with these mods, if your low side keeps up, which will give you a bump in octane and let you keep some timing in it.
As a similar comparison, I just tuned a C7 Z06 with X port, 103mm Soler TB, stock pulley, 2 inch headers and E40. Car put down 715rwhp and ran low 10's. Then changed to a 2.3 upper, meth and E55 and the car ran 9.9x @ 143x at the track last weekend.
GM Gen V Calibrator
Old 06-10-2024, 11:51 AM   #5
race24x
I ran E85 in my SS build, it was awesome, but it is so hard to get up here I was going to stick to pump gas. I really didnt want to put headers on. Will the cooler temps up here help a little with heat soak? We dont get a lot of 90 degree days LOL. I can skip the 2.3 pulley, but I just thought if the blower would be off anyway it would be an easy upgrade.
1980 Z28 AWSM-Z
1993 Z28 AWSM-Z
2014 2SS AWSM-SS
2018 ZL1 AWSM-Z
Old 06-10-2024, 12:51 PM   #6
KamZL1
KamZL1's Avatar
Drives: Z06
man look I had the same reservations about the headers but I promise it's only loud on startup and throttle. With the valves closed, I find it quieter than stock. and I removed all the cats
KamZL1 is offline   Reply With Quote
Old 06-10-2024, 05:46 PM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
Research a bit more before doing those exact mods! I did the Kong X-port and a 2.3" Griptec. I quickly found out after doing so, I didn't have enough fuel system.[/URL]
That's curious because my hpfp, on my previous and current motor, can make at least 1000 wheel on 100 octane. Perhaps I'm not following...
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 06-10-2024, 06:07 PM   #8
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
On race gas lol… huge difference in fuel system headroom between E and race gas. Probably on the order of 40%.
Old 06-10-2024, 07:08 PM   #9
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
What sort of numbers are you seeing as far as an gains are concerned on a standard port Jason? Starting to consider porting the blower on the standard side given that I'm seeing good numbers with the mods in my signature.
758 HP/ 804 TQ
Old 06-10-2024, 07:19 PM   #10
2023_ZL1-AUTO
Drives: 2023 ZL1
Not to squat on OP's thread, so with a 103 TB, X-port, 2.3 upper, Flex Fuel sensor (E60 at the time), stock fuel system and stock fuel pump (except for a JMS Voltage), 2" headers, misc other mods. My fuel pressure PSI 400psi to 600psi lower than command at top end and power just went flat. Maybe I just had a bad stock fuel tank pump?
Old 06-10-2024, 08:51 PM   #11
Katech_Mike
Drives: 2015 Camaro ZL1
With race fuel and a cam.
Stock cam and E is hard pressed to make more than 650-670rwhp with the E content being E30 or less on a non happy Dyno using SAE correction.
Katech_Mike is offline   Reply With Quote
Old 06-11-2024, 04:52 AM   #12
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
You dont need a Big Gulp with those mods, more airflow than your motor can use efficiently. A regular Rotofab would work better.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 06-11-2024, 08:00 AM   #13
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Depending on the setup there is a 20-40rwhp difference up top. However, to be honest, the X port doesn't really feel so great down low unless you speed up the blower. I know you see dyno tests that show an x port making more power everywhere above 3000 rpm with a stock pulley vs a stock non ported blower. But keep in mind that is a loaded high gear pull that gives the blower time to move some air. In the real world, in low gears around town, torque is down and the car feels a bit sluggish. But at WOT in the higher gears there is an advantage. Down low in the lower gears it doesn't have enough time to make boost and isn't any faster than stock. A standard port would fair better here. I guess in short, the X port moves the power more to the right.
If you do an X port you really should at least add a 2.35-2.38 upper pulley, but optimally the 2.3 upper is the sweet spot where it makes up for the low rpm sluggish feel in lower gears and then really pushes some air up to redline. But you also need to be able to get some E in the car to really push the power so you have to address the fuel system.
The expensive path, but clean and reliable path is upgrading the DI system or adding port. For some real world examples, my MANUAL transmission Z06 was flirting with the 5's on a 60-130 draggy with just the below mods. And I had to start in 3rd which wasn't optimal as I was on stock tires. Rotofab big bulp, Soler 107mm TB, Kong X port, 2.31 upper, LPE BB HPFP, DSX Aux, XDI30% injectors, E65, 1 7/8 headers and the car ran a 6.0x 60-130 draggy.
I'm going to be doing the same mods to my ZL1 but the ZL1 is heavier although it has the 10 speed auto. I've already got the ZL1 in the 6.90's with the following mods: Big Gulp, Soler 103mm TB, 1 7/8 headers, Kong X port, 2.3 upper, JMS on E30. I'm waiting on the new Katech hpfp to drop in with XDI 30's to see what I can do. I was going to test port but DSX is taking too long and were going to save the DSX port testing for the 3.0 Whipple ZL1 we are working on.
Anyhow, both of these cars draggy times are on STOCK tires. So with a better tire I expect the times to drop.
You can't run E60 with those mods. E30-35 is about the max the stock HPFP will support at this point and pressure will start dropping fast. Power probably fell flat because you were pushing the limits spraying too far into the compression stroke. You would have been OK on E30 and a tune that addresses the spray window.
GM Gen V Calibrator
Old 06-11-2024, 08:48 AM   #14
KamZL1
KamZL1's Avatar
Drives: Z06
Please do a thread on whipple build, i know a lot of us are curious on how it compares to 2650
