@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Whipple Belt Size
Hi Guys was looking around on the site, found some information but not exactly what I was looking for and maybe start another useful tread as the one that exists if for ZL1's on the 8 ribs.
Currently my setup is 8.855 Lower / 3.375 Upper // Belt K100852HD Im seeing about 15-16psi. I have a 3.0 at home that I want to use. Next belt down is a K100830HD which is almost 2in smaller... I would assume I would need to use the existing belt? Anyone have this pulley combo? 8.855 / 3.0? What belt are you using? Thanks in advance.
Florida High Performance: H/C Whipple LME 377 900WHP
#2 | |
Moderator
https://www.daycoaftermarket.com/wp-...2019_GUIDE.pdf
#3 | |
@Blackmamba_1LE
I've only ever used Gates, this Dayco brand would you say is at same level?
#4 | |
Moderator
