![]() Drives: 20 1SS 1LE Join Date: Sep 2023
Reverse Camera Low Frame Rate
As the title states, my reverse camera has been randomly a notably lower frame rate than it was when I got the car. From what felt like a consistent 60FPS to around 20. Was occasional, now its constant.
I'm not sure if this is the camera itself that's faulty or something else. I can't find any information online of other people with a Chevy or specifically 6th Gen Camaros having this same issue, just complaints of resolution. Anyone familiar with this problem from GM or Camaro? Know if this is a problem with the unit or a gremlin? I think I've found the part number for the camera online #85536893 but can't find much other information about it either. '20 1LE 1SS M6 19k mi. I do have aftermarket tail lights but I don't remember if the wiring harness to those connects to the harness for the camera. If anyone has any insight or information to a potential fix that'd be great. |
![]() Drives: 1987 IROC, 2020 ZL1 Join Date: Nov 2023
could be an indication of a failing camera. Also might have a layer of dirt on the lens which the camera then needs to drop the frame rate in order to allow enough light in for the sensor to operate. Think the sensors used are pretty low quality so even a very slightly darker image might force a frame rate drop
![]() ![]() ![]() Drives: 24 LT1 M Join Date: Oct 2015
Mine does the same thing on my '24. Chevy did an update on mine but the issue still seems to happen..
https://www.camaro6.com/forums/showthread.php?t=625325
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30 |
