Old 05-05-2024, 09:38 PM   #1
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Reverse camera laggy/jittery
More often than not the video from the reverse camera seems very laggy or jittery when moving. I've been reluctant to take it to the dealer to have them look at it as it usually takes 5+ days before anyone even looks.
Looking to see if anyone else has issues and or if there is a fix I can do?
I have not factory reset the radio system, that was something I was thinking of doing, but any other suggestions or anyone else have a similar experience?
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 09-21-2024, 07:33 PM   #2
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Well I finally got around bringing it in for the radio/cam issue. I also discovered some other odd issues with the radio system, steering wheel volume controls were acting like they were stuck, one click on the button would increase by 5x or more.
Turns out, there's a fix TSB for this issue. I also had two codes in the system:
B395A Rearview camara signal invalid (I don't even have a rearview camara)
U0184 Lost communication with radio
TSB: https://static.nhtsa.gov/odi/tsbs/20...52123-0001.pdf
Update radio software
22 Mazda CX-30
Old 06-23-2025, 05:32 PM   #3
havelegs
havelegs's Avatar
Drives: 24 LT1 M
I think I fixed the problem. I tightened the ground cable in the engine bay. I have not seem to have the issue so far, but still testing as I do not drive the car too often. Hopefully, that was the fix.
22 Mazda CX-30
