Old 04-19-2024, 01:35 PM   #1
GreyGhost702
Drives: 2019 Camaro 1SS1LE
12v switched power
2019 Camaro 1SS 1LE M6
I have beat this to death in google and this forum. Is there no key-on fuse power in the trunk location?? I have tried every fuse and every fuse is hot all the time. I am trying to give my wideband gauge a key on source without tapping shit under the dash or console, ran a clean wire to the trunk. Nothing in the trunk is key on?
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 04-19-2024, 04:31 PM   #2
ChibbMD
Drives: 2022 SS 1LE
I should probably post this in the DIY section for future reference. In the picture below (fuse box in the trunk), the purple wire with the red arrow is the ACC circuit (only on when the car is turned to ACC or ON). You can tap into this wire/circuit. Disregard the wire with the probe. That is not it.
ChibbMD is offline   Reply With Quote
Old 04-20-2024, 01:40 AM   #3
GreyGhost702
Man you are a life saver. I was about to gut this pig lol. Will save my add a fuse for another battle. Pretty sure I have a tap somewhere and an inline fuse. Thanks a bunch!
Old 04-20-2024, 06:48 AM   #4
Val Walkinshaw
L8ap3x
Val Walkinshaw's Avatar
Drives: 2018 2SS 1LE
Absolutely correct. I tapped into this as well for my jammers and it's been flawless.
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M
Val Walkinshaw is offline   Reply With Quote
Old 04-20-2024, 10:08 AM   #5
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Thx for this ChibbMD
Old 04-20-2024, 05:18 PM   #6
ChibbMD
Drives: 2022 SS 1LE
Happy to help! I remember how much difficulty I had getting a clear answer on this, so I was excited to have an answer for you. Also, I definitely agree with an inline fuse, just for precaution.
By the way, this is now in the DIY section and hopefully easier for people to find in the future.
Old 05-25-2024, 01:12 PM   #7
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
I was adding some Wide bands and wanted switched power. This is the ticket!
I was wondering if there are any switched fuses so I could use an "add a circuit" instead of a tap. Lots of angst and investigation later, there are some!
F33-WCM "wireless charger"
F19-frt vent seat
F17-Spare
F12-htd str whl
I used the spare, F17, circled in yellow.
the other add a circuit is for an intercom, it is in F23, BCM 1, constant 12v
I'll add this info to the DIY thread
Thx to ChibbMD for getting this started!
