04-17-2024, 03:32 PM | #1 |
Drives: Nickey Super Camaro Join Date: Nov 2008
2022 LT4 Internals vs prior LT4
Anyone know the intimate internal parts changes/differences on the 2022 and up LT4s? |
04-17-2024, 03:49 PM | #2 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I can't help but ask, why would it be different?
04-17-2024, 04:16 PM | #3 |
Drives: 2022 ZL1 1LE Join Date: Sep 2015
Hi all,
I don’t know if there are any internal (mechanical parts) that are different, but the engine management software in my ‘22 ZLE M6 is miles above better than what my ‘18 came with. No more off idle stumbling, no more charcoal black wet exhaust tips, better gas mileage, and better overall performance. IMO, my ‘22 is a far better, improved car all around. JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
04-17-2024, 04:51 PM | #4 |
Our GM Repair link was showing some different part numbers, but turns out that it is a mistake. No internal parts differences.
04-17-2024, 04:53 PM | #5 |
04-17-2024, 06:44 PM | #6 |
Drives: 2016 2SS Convertible Join Date: May 2012
04-17-2024, 07:28 PM | #7 |
I read that GM changes part numbers whenever they change suppliers for a part even if specs remain identical, but I'm not on the inside, so not sure if that's the case here.
04-18-2024, 03:53 AM | #8 |
04-18-2024, 09:08 AM | #9 |
Drives: '23 Camaro ZL1 A10 / '23 Blazer RS Join Date: Apr 2023
I might be wrong but weren't the fuel injectors also slightly changed/increased flow for 2022+ years?
2023 Camaro ZL1 A10
Riverside Blue Coupe 1/16/23 - 1100 4/20/23 - 2000 5/08/23 - 3000 (TPW-5/22) 5/12/23 - 3400 6/01/23 - 4150 6/05/23 - 5000 6/07/23 - 6000 |
04-18-2024, 09:18 AM | #10 |
04-18-2024, 09:23 AM | #11 |
GM changes part numbers on the same parts all the time.
2016 NFG 1SS A8
04-18-2024, 09:35 AM | #12 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
It's for lot traceability. If you start getting failures / returns of a unit, or system, you can start using information like what part numbers changed around that time to help track down and troubleshoot issues. Sometimes it can be an entirely different part number, or sometimes just a revision. That comes down to company policy in my experience.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
04-18-2024, 11:31 AM | #13 |
Petro-sexual
The injectors referenced above might be the Escalade V injectors, which flow a little more, but are physically smaller.
