Old 04-03-2024, 12:22 PM   #1
Ssls1
Drives: Chevrolet camaro
2016 Camaro Ss Fuel/Evap System Not Ready
Hi guys. Recently changed fuel pump and fixed bad connector on fuel pump module. Car i had left me stranded. The car now runs fine. No codes. Took the car for state inspection recently and my fuel and evap system said not ready. I drove car another 150 miles and it still says the same. Anybody experience this before. My car passed last yr just fine.
Ssls1 is offline   Reply With Quote
Old 04-03-2024, 12:36 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
There is a very specific set of criteria needed to get that monitor to set as “Ready”. Google the OBD-II drive cycle to get an idea. But on that one you’ll likely need to drive the fuel tank down low, then fill it up, then do a cold start. Or something to that effect. It can be a pain lol.
Old 04-05-2024, 11:43 AM   #3
Ssls1
I have driven the car over 200 miles and its still in not ready status. Does anyone know how long it takes to be ready for emissions. I did have a lean code before all this. I usually mix E85 with 91. I think it was because of that. I reset the codes and drove the car 250 miles so far.
Old 04-05-2024, 11:54 AM   #4
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
As stated above you you need to drive the specific cycle. Typically easiest to do that is on a deserted 2 lane hwy as there's a lot of speed variation and braking. However, evap takes forever to clear. Like hundreds of miles. I went thru this on a battery change in an Avalanche just before inspection when I lived in NY. Failed all the readiness codes. Spent 20 minutes on the drive cycle, brought it back and passed all except for evap. But in NY you only needed to pass 3/4 codes. Not sure about where you are at. If you can clear the fuel code maybe it will pass without evap.
Old 04-05-2024, 03:54 PM   #5
Joshinator99
Moderator
Did you read what I wrote above…? It’s NOT mileage related. If you don’t hit the specific criteria, it won’t show “ready”. Period.
Old 04-05-2024, 04:17 PM   #6
ctrlz
Reading poisons the mind.
Stick with tik-tok.
Old 04-05-2024, 05:56 PM   #7
Deacon Blues
Drives: 2024 Camaro 1SS M6
How long ago was that the case? I've never been able to pass a NYS inspection if my EVAP wasn't ready. I had a Chevy Colorado that had a persistent EVAP leak I couldn't track down, and it was a juggling act to clear the code and have enough time to get the data to at least read "ready" or "pending" to pass.
Deacon Blues is offline   Reply With Quote
Old 11-25-2025, 02:41 PM   #8
tortilla-flats
tortilla-flats's Avatar
Drives: 2023 Camaro 2SS
I'm running into this issue too. Tried everything suggested. The problem is all the suggestions are generic and say follow a the specific sequence but no one says what that specific routine is.
Does anyone know exactly what the drive cycle is for a 6th Gen Camaro LT1 A10 is?
Camaro SS - (almost) FBO/E85: Tuned by Snackbar Tuning/21st Century Muscle Cars
tortilla-flats is offline   Reply With Quote
Old 11-25-2025, 03:40 PM   #9
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Is your car tuned?
Old 11-25-2025, 03:50 PM   #10
tortilla-flats
Yes.
Old 11-26-2025, 04:28 PM   #11
flobb
Drives: 2022 2SS
It's a massive pain in the arse. These look like the instructions I followed~ish when I had to deal with EVAP not ready. https://www.camaro5.com/forums/showthread.php?t=176410
Some of these steps are downright dangerous because they have you coast from highway speeds down to 20mph. For me, I was fortunate enough to have a highway interchange that gets virtually zero traffic and an inclined ramp to help the deceleration.
flobb is offline   Reply With Quote
Old 11-26-2025, 05:29 PM   #12
tortilla-flats
Thanks for that. Was there a specific post that describes what worked for you? That thread is all over the place with inconsistent & contradictory information.
-- All electronics off vs on for cold idel test
-- Miles vs minutes
-- Cruise yes vs no
There's even a link to use a Tech 2 process.
I agree some of these driving instructions are down right dangerous. Reads like it has to be done on a closed course.
Old 11-26-2025, 06:26 PM   #13
bishopts
bishopts's Avatar
Evap on GM vehicles is about as easy as getting a liberal and conservative to apologize to each other. It's specific to engine temperatures and engine run time, along with fuel level and the statis of other monitors readiness. If you do normal drive cycles for a few weeks then it might switch to ready as long as no problems are detected and you don't have history failure codes stored.
If you have a history code in the system it needs to do the required pass sequence to clear the code and then do it again to set the monitor to ready.
For example, if you have a history p0420 for catalyst efficiency. And that monitor needs to see 3 full drive cycles to switch to ready. You will need to do a total of 6 runs of engine at operating temp, 15min constant throttle highway runs around 60mph, then come to a stop and wait 3-5 mins at idle.
Fuel monitor is a big umbrella of codes its monitoring. Most having to do with cam timing and desired vs actual fuel pressures. On top of readiness of o2 monitors.
Since my car didn't have cats when i bought it i have o2 and cat codes that will never go away. I removed all emissions codes and changed all fuel and timing codes to "no mil", that way if i need to reference them for repairs i can. But for the most part i can disconnect my battery and hook it back up and my monitors are all ready.
Old 11-26-2025, 08:03 PM   #14
vince3
Drives: 2022 Vivid Orange LT1-M6
So if rear 02s are deleted, no passing emissions?
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
